No reverse - Kawasaki ATV Forum
post #1 of 9 Old 02-11-2013, 07:05 PM Thread Starter
No reverse
I have a 99 Prairie 300 4x4 KVF300. About a year ago I was having carburetor issues and the motor kept stalling out. I have since rebuilt the carb and it works like new.
However, one of the ripple effects of the bad carb was that we had the idle turned up to keep from stalling. This resulted in slamming whenever the gear selector was moved from neutral, either to H or R.
Recently, the reverse gear stopped working. That is, you can move the lever into position but the light does not come on, nor does the transmission shift into reverse.
I have looked around on the forums and the likely causes are a damaged shift fork or broken reverse gear chain.
In looking at the Kawa Service Manual, it looks like a daunting process: pull the motor, pull the tranny, split the crankcase, fix parts and put it all back together again. One estimate I got today was for $700 in labor plus parts.
I know its my own damn fault for running it like I was , so now what I want to know is how hard is it really going to be if I do this myself? Has anyone done this? Are there any other likely causes? What other resources are out there for this process?
turbodogz is offline
post #2 of 9 Old 02-12-2013, 04:38 AM
Feedback Score: 3 reviews
rdm531's Avatar
should not be that hard i split the v- twins all the time with no problems ,just follow the service manual
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #3 of 9 Old 02-16-2013, 08:38 PM
Cool
Let me know how this goes for you. I have the same issue. Was pushing snow with my prairie 300 4x4 and it was about to stall so I hit the throttle and slammed it into reverse. Did not move an inch. Tried to go forward and could only here very bad grinding noises. I'm guessing I broke a fork in the crankcase. I can get the forward gears to engage by moving the shift rod and trying to turn the drive shaft. When i put it in reverse the drive shaft just spins freely. Have the right side apart down to the clutch but need help getting that thing of the crankshaft! Do I just need to buy one of those pullers/pushers? Do I have to remove the spider first? Can I just get into the crankcase from this side or do I need to take the entire engine apart? I will be ordering a manual tomorrow!!
Benzump is offline
post #4 of 9 Old 02-17-2013, 05:57 AM
NovaKaw650's Avatar
Garage
Quote:
You need a puller for the clutch specifically for the 300; NOT the 360, 650, 700, 750.
Pull the engine out of the frame, get a factory service manual, and split the cases.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is online now
post #5 of 9 Old 02-27-2013, 08:21 PM
Got the puller from a dealer and using an impact wrench was able to get the clutch of in about 20 seconds!!! I have the entire engine, tranny,etc out of the frame. First thing I found wrong was the front bevel gear had some chewed up teeth and the rear bevel gear was missing about 4-5 teeth!! Well they weren't missing they were in the gear case. Now that the engine is out I am having trouble splitting the case. I have all the bolts out including the ones that are hidden behind the pull rope cover. I can get it about 3/8 to 1/2 apart but no farther. Do I have to get the head off first? Do I need to get the tensioner chain off first? I don't have a manual yet have just been using parts diagrams so far. Any help would be appreciated. Thanks
Benzump is offline
post #6 of 9 Old 02-27-2013, 08:42 PM
NovaKaw650's Avatar
Garage
You're going to need a service manual for this one.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #7 of 9 Old 02-28-2013, 03:51 AM
rdm531's Avatar
are you saying the cylinder an head ,are still on the engine,
custom cut clutches
rdm531 is offline
post #8 of 9 Old 02-28-2013, 11:13 PM
I got the crankcase to split!!!! I indeed did still have the head on. I took the tensioner chain off and that allowed me to get the head off and then it was no trouble to split the case. The culprit was a broken reverse chain in the transmission. Although what came first the chain break or the gear teeth???? Anyway, I ordered a manual tonight and about $700.00 in parts to start the repair and attempt to put everything back together again. Any tips on how to compress the spring on the rear drive shaft to be able to get the nut back on - luckily nothing went flying too far when the nut came loose!! Also, I couldn't see on any parts diagram a gasket for in between the two halves of the case? Should I use some type of gasket goop in there?
I am a relatively inexperienced with this type of repair work, but I had alot of time to kill and didn't want to pay a shop to take everything apart. Thanks.
Benzump is offline
post #9 of 9 Old 02-10-2014, 08:26 PM
Once you got things apart what ended up being the issue? I just recently bought a 1999 prairie with no reverse
pennell33 is offline
Tags
gear, kvf300, reverse, selector, transmission
2002 kawasaki prairie 300 no reverse
how do you fix reverse on a 2002 kawasaki prairie 300 4x4
how do you repair kawasaki boyuo 300 4/4 with no reverase
kawasaki kvf300 reverse not working
kawasaki mule no reverse
kawasaki mule reverse only no norward
kawasaki prairie 360 slamming into gear
kawasaki prairie no reverse
kawsaki mule won't go in t o reverse
prairie 300 hard to shift
reverse chain in kawasaki prairie 300
reverse for kawasaki 300
no reverse sleddkid Kawasaki Brute Force/Prairie/Bayou 0 06-02-2012 06:52 PM
Low rpm and reverse VFORCE04 Kawasaki KFX700 V-Force 12 04-28-2011 01:44 PM
reverse help please mabjr29 Kawasaki Mojave/Lakota 6 01-25-2011 02:38 AM
Reverse DoubleTapXX Kawasaki Mojave/Lakota 3 02-14-2010 10:57 AM
goes from 1st to reverse triktecate Kawasaki Mojave/Lakota 5 03-01-2009 04:34 PM
