clacking noise if engine idle too low - Kawasaki ATV Forum
post #1 of 5 Old 03-14-2013, 02:15 PM Thread Starter
i just put a 2012 engine in my 650i because the other one had a knocking rod bearing. this one sound good and rev good but if i put the idle low it start to make that noise. maybe timing chain?? that engine only have 1000km
i checked the 2 timing chain tensioner and they are almost all the way in so the timing chain its not stretched. could it be the valve??
i play with the idle knob to make the noise go and back.
2006 Brute force 650i
EHS lid with stock intake blocked
full muzzy exhaust
twin air filter
Dynatek
Aluminium product skid plate
Scortadict is offline
post #2 of 5 Old 03-15-2013, 05:50 AM
Feedback Score: 1 reviews
If your idle is really low it could be the auto decompressors on the cams engaging and disengaging, turn up you idle a little and see if it goes away
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #3 of 5 Old 03-15-2013, 12:14 PM Thread Starter
Yes it go away if i turn up the idle. My other engine never did that but with that engine i had to close way more the tb to idle at normal rpm
full muzzy exhaust
twin air filter
Dynatek
post #4 of 5 Old 03-15-2013, 01:20 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
It acts like the springs on the decompressors are too heavy and are trying to reset at slow speed.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 5 Old 03-15-2013, 07:01 PM Thread Starter
thanks for the info. the new engine run great!! but i was in the 14 af ratio so i will jump 2 size of main jet, 172 175.
full muzzy exhaust
twin air filter
Dynatek
2012 honda crv engine noise at idle
atv engine noise at low rpm
atv engine noise low revs
atv engine sound low idle
atv idle makes engine noise
boat engine with idle too low
kawasaki bayou 250 engine knocking
kawasaki bayou 250 making a rattling sound
kawaski engine in john deere gator making a knocking sound at idle only
lakota engine rattle
low engine idle noise goes away boat
polaris atv idle sound
why does my 650 prairie idle too low
Engine ticking @ idle RED13X Kawasaki Mojave/Lakota 7 04-07-2012 08:35 PM
clacking noise in the brute builtbrute05 Kawasaki Brute Force/Prairie/Bayou 5 03-17-2011 12:20 AM
clacking noise in the brute builtbrute05 Kawasaki Brute Force/Prairie/Bayou 0 03-16-2011 05:57 PM
Clacking noise, bf750 2009 countyingula Kawasaki Brute Force/Prairie/Bayou 10 07-12-2010 05:48 PM
750 brute force engine idle noise chine Kawasaki Brute Force/Prairie/Bayou 1 09-04-2009 07:14 PM
