03 Prairie 650 - Kawasaki ATV Forum
post #1 of 7 Old 04-05-2013, 07:29 PM Thread Starter
03 Prairie 650
Hello everyone,
I am having a problem with the KEBC on my step dads Kawi. the engine brake is squeeling.
The problem is with the bike in gear the acutator extends the forks of the engine brake. I am unsure with the issue is. It works just backwards.
Any help would be great.
Thank you
Medman
medman is offline
post #2 of 7 Old 04-05-2013, 07:50 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
By any chance has he just installed a new belt?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 7 Old 04-06-2013, 03:34 AM Thread Starter
Quote:
Yes he did prior to brining it over.
medman is offline
post #4 of 7 Old 04-06-2013, 04:34 AM
NovaKaw650's Avatar
Garage
If the problem started when the new belt was installed, then there's nothing wrong with the KEBS. The belt is too tight. If it's chirping or squealing, but not creeping ahead in gear, you can leave it as it is. If it's creeping, you will need to adjust the belt deflection. It's actually the best set-up for performance and belt life as long as it doesn't creep in gear. Eventually the belt will wear a bit and the squealing will become quieter and likely go away.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #5 of 7 Old 04-06-2013, 08:43 AM Thread Starter
It does creep alittle but not bad. However the KEBC engages when I put it in gear and really starts to squeel. I rode the bike alittle with the cover plugged in and in hand and no squeel, but the KEBC fork was engaged untill i put the bike in N.
Medman
medman is offline
post #6 of 7 Old 04-06-2013, 10:45 AM
NovaKaw650's Avatar
Garage
Medman
The KEBS is working properly; it "pre-stages" when you turn the key on, but doesn't push the clutch in until it's needed. When the KEBS malfunctions and stays "in", it doesn't creep; it drives off and stalls when you hit the brakes to force it to stop.
As I posted above, if it creeps, then adjust the belt tension. If it squeals in neutral, then it's horrendously tight and should not be driven until you adjust the belt.
The short version: adjust the belt.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #7 of 7 Old 04-06-2013, 02:36 PM Thread Starter
thank you.
medman is offline
03 650 prairie reviews
03 prairie 650
03prairieforce
650 prairie new belt trys to pull when idling
belt stayin engaged on a fourwheeler
changed belt on 650 prairie and it trys to go forward
kawasaki prairie 360 beltg stays engaged
kawasaki prairie 360 oil capacity
kawasaki prairie 650 chirps
kawasaki prairie creep
kawasaki prairie creep and chirp at idle
kawasaki prarie 650 differential causeing it to creep
prairie 650 creeping
Pulling a engine on a prairie 700 and putting it on a prairie 650. onebadprairie Kawasaki Brute Force/Prairie/Bayou 11 05-14-2013 10:04 AM
03 Prairie 650 Motor in 02 Prairie Chassis Kawidan Kawasaki Brute Force/Prairie/Bayou 2 01-14-2013 03:28 PM
Will a front differential from a 2005 Prairie 360 work with a 2003 Prairie 650? David1985 Kawasaki Brute Force/Prairie/Bayou 11 08-30-2011 06:08 AM
lte for prairie and head prairie with 1.5 mm valve over brute 665 For Sale 3 11-17-2008 01:46 PM
04 Prairie 700 motor in 02 Prairie 650 Chassis Kawidan Kawasaki Brute Force/Prairie/Bayou 4 03-09-2007 03:53 PM
