09 Brute fuel pump relay issue - Kawasaki ATV Forum
post #1 of 18 Old 04-06-2013, 02:59 PM Thread Starter
Feedback Score: 2 reviews
Whopper's Avatar
09 Brute fuel pump relay issue "wiring position"
I have been working on my 09 Brute Force 750 recently purchased quad that has had some very interesting backyard scab repairs done to it . Ive been fixing or redoing them all week. Today i touched the fuel relay under the seat and found out the factory connector is gone and the wires are just put directly to the relay with connectors. Problem was that the wires came off and now I don't know which wire goes to which pin on the relay. Can someone take a pic or explain to me where each color wire goes. I've been playing with it but no luck on getting it right since the motor won't start
DON'T MESS WITH A SASQUATCH EH!
WWW.EXTREMEMACHINES.CA
"BROKENLINK" http://youtu.be/0RJuV-LwlM0
Whopper is offline
post #2 of 18 Old 04-07-2013, 10:00 AM Thread Starter
Whopper's Avatar
45 views and no one can help me out...... If the damn shop manual would help me out it be fixed already I'd think, but it doesn't show wire position in the connectors just the wire schematics
Whopper is offline
post #3 of 18 Old 04-07-2013, 10:05 AM
My 09 did exactly the same, i soldered new conectors with lotsa die-electric grease. I got dealer to send me elec schematic, bud had the samr quad to look at also. My fan relay also did this.
2014 t2 800 N PARTS! NOW GET THE FAWK OUTTA MY WAY!
EFFIN750 is offline
post #4 of 18 Old 04-07-2013, 10:40 AM
drewlawrence's Avatar
I looked at the manual and it says Y/R and BR/Y Go to the coil. And W/R and W/G Go to the Normally open contacts. PM Me If you need more Help. Bottom Right hand Corner.
2010 Brute Force 750
Nocturne Blue
VFJ Stage 3 Spider Mod
Full Muzzy Pro
VFJ MSD
Warn XT25
27" Mudlite XTR's
Moose Utility Front/Rear Bumpers
Temp guage, Fan Override
Symtec Heated Grips
SATV Ez Steer
1.5" Spacers All Around
drewlawrence is offline
post #5 of 18 Old 04-07-2013, 11:11 AM Thread Starter
Whopper's Avatar
Quote:
These wireing harness sure suck big time.... I can't believe how bad of shape so many connections are. My fan relay is still there for now but the relay itself wasn't turing on the fan it was just clicking, thats what I was playing with when I saw the mess on the fuel relay and my issue got worse fast
Whopper is offline
post #6 of 18 Old 04-07-2013, 11:12 AM Thread Starter
Whopper's Avatar
Quote:
PM sent......
Whopper is offline
post #7 of 18 Old 04-07-2013, 11:32 AM
Hold the relay with the lettering on top, looking at the pins.
white-green to top/left
white-red to bottom/left
yellow-red to top right
yellow-brown to botom right
Hope that helps you.
windriver is offline
post #8 of 18 Old 04-07-2013, 02:17 PM Thread Starter
Whopper's Avatar
Thanks for that info..... That would be what im after
Whopper is offline
post #9 of 18 Old 04-07-2013, 03:42 PM Thread Starter
Whopper's Avatar
Its a no go....
It must have cooked something when the wires fell off the relay cause now the pump doesn't turn on with the key but will if I jump the connection. Looks to have power at the coils but no spark at the plugs. All fuses are good too.
Shitty deal.....
Whopper is offline
post #10 of 18 Old 04-07-2013, 08:33 PM
Swap it out with the Fan relay. They are all the same. 1 Coil and 1 set of NO contacts. Check you PM's.
Nocturne Blue
Full Muzzy Pro
VFJ MSD
Warn XT25
27" Mudlite XTR's
Symtec Heated Grips
SATV Ez Steer
08 brute force brown wire on fuel relay
08 kawasaki brute force fuel pump relay
09 kawasaki 750i brute force fuel pump relay
atv fuel relay
brute force 750 fuel pump relay
brute force coil power wire colors
brute force fuel relays
brute force main fuse block just clicks once no power
fuel pump 09 brute force
fuel pump for 09 brute. 750
fuel pump relay for 2010 750 brute force
is there a fuel pump relay on a kawasaki brute force
New Brute Fuel Pump 08-13 Lee Kawasaki Brute Force/Prairie/Bayou 1 12-28-2012 06:56 PM
R&R Brute fuel pump mjn Kawasaki Brute Force/Prairie/Bayou 3 02-20-2012 03:49 AM
09 Brute Force 750 Fuel Pump KawiGirl09 For Sale 6 02-19-2012 03:05 PM
05 750 Brute electric fuel pump, leaking issue. HELP bigm357 Kawasaki Brute Force/Prairie/Bayou 17 05-16-2011 09:31 AM
Electric fuel pump mod for Brute 650's with vacuum fuel pump VFORCEJOHN Interstate Motorsports 0 04-14-2009 02:21 PM
