Hi the thing is that I have a brute force 750 2013 and is beating me up
The problem is that the ATV is not cooling the right way... For example I run the bike and the water temperature rise to 90*c (Celsius) the fan manage to cool it to 86*, 84* but very slow, some times get the job done and cool it down to 79* where the fan stops, but mostly if I help it with water.
I have access to an Scaner that's say me real time the temperature the fan stars to work at 87*c (Celsius) and stops at 79*c as is spouse.
The radiator is clean.
The Water pump is fine (remove the cap and check)
The fan breaker is fine
The sensor is working fine because I test it!
The Fuse is good
The relay is good
What I'm afraid is that the amperage of the fan... I have the service manual but it doesn't tell me what the amperage it suppose to be....
I don't know... It's driving crazy
I don't want to go to the dealer because I'm in panama and the only know the change the oil... If I go with them they will start to change parts until the "fix" the problem but not in less than 4 months...
Can any body tell me the amp right amp of the fan? Or give me an idea, if I'm missing something.
Thanks!
The Fuse is good
The relay is good
Thanks!
