98 prairie 400 4x4 shift problems - Kawasaki ATV Forum
post #1 of 4 Old 05-05-2013, 01:18 AM Thread Starter
BioHazard's Avatar
i picked up 2 prairie's today in trade for an old polaris i had. the one i'm working on first is the a 98 400 4x4 and it won't shift into forward and will go in reverse only and some time's neutral if i'm lucky. i unhooked the linkage from the shifter for hi/low and the forward/neutral/reverse. the hi/lo lever on the the motor moves good and i can tell that it's switching in and out on that. but the shaft for f/n/r seems like its in a bind and hard to move by hand and no matter where it clicks in place its usually only going in reverse and sometimes neutral if i'm lucky. the lights show that its going into gear but it isn't. i've been lucky so far with not having to split cases but looks like i'm going to have to with this one. any tips on what's causing it?
BioHazard is offline
post #2 of 4 Old 05-05-2013, 05:06 AM
Feedback Score: 3 reviews
rdm531's Avatar
bent shift fork or gear busted
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #3 of 4 Old 05-08-2013, 11:00 AM Thread Starter
BioHazard's Avatar
well got it apart and had a broke gear and a bad shift fork. where do you guys get you gears at can't find them anywhere.
post #4 of 4 Old 05-09-2013, 05:56 AM
rdm531's Avatar
dealercostsparts, is where i get most of my stuff
custom cut clutches
rdm531 is offline
1997 kawasaki prairie 400 4x4 trans wont go into gear
1998 kawasaki 400 bayou 4x4 wont shift into reverse
1998 kawasaki prairie 400 4x4 reviews
1998 kawasaki prairie 400 wont go into reverse
1999 kawasaki prairie 300 will not go in gear
1999 kawasaki prairie 400 wont shift into reverse
2000 kawasaki prairie 400 4x4 not shifting while in high gear
2000 kawasaki prairie 400 4x4 shift lever
98 kawasaki prairie 400 4x4 problems
kawasaki prairie 300 in gear but won't move
kawasaki prairie 400 transmission problems
problems switching gears on a kawasaki prairie 300
shofting problems kawasaki prarie 300
2000 Kawasaki prairie 300 4X4 shift lever, search didn't answer my ? remofire Kawasaki Brute Force/Prairie/Bayou 13 02-15-2012 07:59 PM
shift problems weinzerl Kawasaki KFX450/KFX400 1 06-22-2011 01:52 PM
730 prairie problems Eustismudder Kawasaki Brute Force/Prairie/Bayou 11 05-08-2010 11:00 AM
Prairie 360 won't shift into gear cnw20 Kawasaki Brute Force/Prairie/Bayou 3 11-07-2009 03:12 PM
still having problems w/shift linkage? vtprairie03 Kawasaki Brute Force/Prairie/Bayou 1 06-27-2004 05:36 PM
