Trouble after 3" snorkel on Brute Force! - Kawasaki ATV Forum
post #1 of 6 Old 10-01-2013, 12:35 PM Thread Starter
Did the mimb 3" snorkel on my 05 brute 750 and when I fired it up, ran poor and was smoking whiteish maybe blue smoke! Rejetted with a dynojunk kit with 144f 148r mains 38 pilot needle at second clip.Went back and forth on air mix settled on 2 1/4 turns pops slightly but runs great throught throttle but continues to blow light smoke when rev'd and sometimes at idle till engine is hot! Never smoked befor snorkel! Any suggestions? Needle position possibly?
MRT71 is offline
post #2 of 6 Old 10-01-2013, 03:54 PM
Feedback Score: 2 reviews
SeanSS's Avatar
Blue smoke would be from oil.
Whitish smoke sounds like a head gasket issue maybe..?
2006 V Force - Just getting started
2004 V Force - HMF Duals, ProArmor nerfs, Razr2's up front, Kenda Bearclaws out back, Turmoil filter, spark plug boot mod
SeanSS is offline
post #3 of 6 Old 10-01-2013, 04:30 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Putting on a snorkel doesn't cause an engine to start burning oil.
Just in case, check for oil in the airbox, under the filter.
144-148 DynoJet jets are BIG. Do you have an exhaust system and cams/pistons, etc?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 6 Old 10-01-2013, 04:53 PM Thread Starter
No oil in air box, stock motor and cams as far as I know, only had the bike a month or so! Stock exhaust except looks to have had the spark arrester remove and larger diameter tip welded on! Runs really good no stutter or bogs!
MRT71 is offline
post #5 of 6 Old 10-01-2013, 08:35 PM Thread Starter
Any chance it could be a sticking choke plunger?
MRT71 is offline
post #6 of 6 Old 10-02-2013, 03:43 AM
NovaKaw650's Avatar
Quote:
The DJ jets are way bigger than stock. Unless it's flowing way more air with the snorkels, it's rich.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
3 snorkel brute force
Trouble pulling flywheel on Brute Force 650 maskay Kawasaki Brute Force/Prairie/Bayou 11 05-11-2015 03:19 PM
Brute snorkel build with 3" center air intake BF750guy Kawasaki Brute Force/Prairie/Bayou 39 03-29-2014 12:16 PM
Brute Force 750 Valve adjustment trouble Need Help!!!! deerslayer365 Kawasaki Brute Force/Prairie/Bayou 21 06-04-2012 02:42 PM
Brute Force trouble dealer canít ID Big John Kawasaki Brute Force/Prairie/Bayou 16 05-09-2011 07:39 PM
2005 brute force 750i trouble GRENON Kawasaki Brute Force/Prairie/Bayou 2 06-17-2009 08:33 PM
