Kawasaki Prairie 300 problem! - Kawasaki ATV Forum
post #1 of 2 Old 10-08-2013, 04:00 PM Thread Starter
hi. new to the forum. did some searching and dont quite understand everything since im pretty new to it.
ive got a 99 prairie. it will start. for about 10 seconds. there is a loud knocking comming from the left hand side of the engine. behind where the pull cord is located. bad knock. and it feels like there is something in there loose and getting banged around. every few turns it seems like it gets wedged in there. and wont allow the motor to crank at all. i took the pull cord off so i could turn the motor with a rachet and i can feel whatever it is in there when i turn the motor.
even when it dosent get stuck and it does start it will only stay running for like 10 seconds and shut off.
any ideas where to start. ive been reading on here alot about rod bearings and clutches but not sure if this is either. thanks.
dereklovejoy is offline
post #2 of 2 Old 10-08-2013, 05:49 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
The clutch is on the opposite side.
The flywheel and stator is on the pullstart side, but if the flywheel is loose it wouldn't run.
You're going to need a mechanic.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
2000 Kawasaki prairie starter problem? dustincraine Kawasaki Brute Force/Prairie/Bayou 3 07-06-2012 09:47 AM
2003 Kawasaki Prairie 650 rear brake problem RALLEYJOE Kawasaki Brute Force/Prairie/Bayou 3 03-26-2012 07:38 PM
Ignition Problem: 1999 Kawasaki Prairie 300 4x4 decon Kawasaki Brute Force/Prairie/Bayou 0 11-08-2011 03:19 PM
will a 2004 Kawasaki Prairie 700 Rear Differential fit 2002 Kawasaki Prairie 650 purpitt Kawasaki Brute Force/Prairie/Bayou 0 10-23-2011 12:49 PM
99 kawasaki prairie problem tomahawkpride69 Kawasaki Brute Force/Prairie/Bayou 3 09-19-2010 06:20 PM
