Prairie 650 Carb help!? - Kawasaki ATV Forum
post #1 of 6 Old 04-16-2017, 07:22 AM Thread Starter
Chillmaster93's Avatar
so i just got my bike back from getting an engine rebuild, and its running rough , im thinking its the carbs .. on a dual Carb if i look down it when its running are both the slides suppose to flutter at the idle RPM of the engine ? and if one of them isn't , could it be the idle screw on the one that isn't moving at idle ? .. my bike is running really rough at any RPM and jumps up and down when i hold my throttle constant at any speed and i noticed that with the carb but the shop is saying its the aftermarket CDI ( Dynatek ) , but it was running fine for months with it before they had it apart .. any ideas ?
2002 prairie 650 ( Frankenstein )
- Suzuki twin peaks 700 Plastics
- 2003 wire harness
- 2003 Engine
- 2003 Primary and secondary clutch?
- Dynatek CDI.
- Suzuki twin peaks front bumper.
- 28 inch zillas
- 2" lift kit
- Snorkeled full 2"
- Manual 4x4 Mod
- Custom Rad relocate
- 2500 LB. Warn winch
- High stall clutch
- Removed KBEC
- Tundra Trunk
-SOON-
- Vforce john custom adjustable weights+springs
-EVENTUALLY-
- Full Muzzy exhaust system
- KVX rear suspension
- durablue Heavy duty rear axle
Chillmaster93 is offline
post #2 of 6 Old 04-16-2017, 09:29 AM
Sounds like a valve adjustment issue. If there's no upper end noise, then I'd guess one or more of your valves are too tight.
Do you still have the factory CDI? Easy enough to put the factory box back in and eliminate that as an issue if you do.
Mrgoodwrench is offline
post #3 of 6 Old 04-16-2017, 09:52 AM Thread Starter
i don't think it would be the valves since the shop just changed everything , and i tried the stock CDI and it's hard to start and still misses abit , and had absolutely no power. i've run the Dynatek for over a year before this with no issues.
- 2003 wire harness
- 2003 Engine
- Dynatek CDI.
- 28 inch zillas
- 2" lift kit
- Snorkeled full 2"
- Manual 4x4 Mod
- High stall clutch
- Removed KBEC
- Tundra Trunk
-SOON-
-EVENTUALLY-
post #4 of 6 Old 04-16-2017, 06:01 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
Yes ^^^^^
And they should flutter at open throttle settings as well.
The idle adjustment has nothing to do with the slides.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 6 Old 04-16-2017, 07:47 PM Thread Starter
any idea what could be causing it ?
- 2003 wire harness
- 2003 Engine
- Dynatek CDI.
- 28 inch zillas
- 2" lift kit
- Snorkeled full 2"
- Manual 4x4 Mod
- High stall clutch
- Removed KBEC
- Tundra Trunk
-SOON-
-EVENTUALLY-
post #6 of 6 Old 04-17-2017, 01:18 AM
VTwinKawi's Avatar
they probably forgot to out a tube back or the one is stuck from sitting, they get crudded up and have to be cleaned once if it sits then could be that
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se (sold)
2006 360 full skids winch (sold)
VTwinKawi is offline
prairie 300 carb prob pbmps Kawasaki Brute Force/Prairie/Bayou 0 08-10-2014 11:03 AM
Kawasaki Prairie 360 Carb RyanK1989 Kawasaki Brute Force/Prairie/Bayou 7 07-12-2014 06:54 AM
prairie 300 carb diaphragm schlieratvrepair Wanted 0 06-12-2012 08:29 AM
02 Prairie 400 carb issue dirtdemon Kawasaki Brute Force/Prairie/Bayou 1 08-29-2010 05:53 AM
prairie 360 carb hose question rap169 Kawasaki Brute Force/Prairie/Bayou 2 06-08-2010 05:26 PM
