So my axle seal was leaking, no big deal until I pulled my left axle out and the needles fell out of the bearing. I cant get the bearing out, do i have to take out the diff. To change it? Any tricks for this?
looks like you have got mud in it would pull it and replace all those bearings, its not going to be easy to put the balls back that way either, they have kits with the seals and bearings, i got on ebay.
have to make sure the spring for the clutch is right too or it wont release.
the one i couldnt get out was the in in the case that the pinion goes into, had to make a tool to jack it out with a long bolt, they were all in there really good
Related Threads
Kawasaki ATV Forum
971.2K posts
52.3K members
Since 2002
