P650 belt shims - Kawasaki ATV Forum
post #1 of 12 Old 10-22-2003, 11:39 AM Thread Starter
P650 belt shims
Im getting ready to tighten the belt for the first time. Everything seems pretty clear except the shim part. Nyroc says buy several so you will have the right ones, but does not say what sizes to buy.
Somebody give me a clue, please.
Sarge
Sarge is offline
post #2 of 12 Old 10-22-2003, 02:13 PM
Feedback Score: 4 reviews
Mikeyboy_esq's Avatar
shims
Sarge,
I recently bought some shims to adjust the belt deflection on my P650 (actually, I'm now running a P700 belt on my P650).
I've read that different people have different stock shims to begin with. Mine came stock with 1 (silver metal) shim at .8 mm and 1 (brass metal) shim at .6 mm for a total of 1.4 mm of width. I've read that some people have only 1 stock shim that is 1.4 mm thick. You can see a pic of these two shims on Nyroc's instructions called "P650 - belt Shim Procedure."
At my first belt adjustment, I only needed to remove the silver .8 mm shim and leave the .6 mm shim on it. That brought my belt within spec. Of course, the exact adjustment you need will depend on how loose the belt is on your particular machine.
I later installed the P700 belt and needed additional shims to adjust it right. I ended up buying 2 shims from my local Kaw. dealer. One was 1.0 mm thick and the other was .6 mm thick and they cost about $5 each. That gave me the most combinations to work with...for example, I could run stock set up (total of 1.4 mm), or two .6 mm shims (total of 1.2mm), or just the one 1.0 mm shim (total of 1.0 mm), or just the one .8 shim (total of 0.8 mm) or just the one .6 mm shim (total of .6 mm). For the P700 belt, I ended up using two .6 mm shims (total of 1.2 mm) to get it within spec.
While I had the CVT cover off, I wiped the sheaves clean using brake fluid. It worked nicely.
Happy trails...
2007 KFX 730 (sold)
2004 Twin Peaks 800 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
Mikeyboy_esq is offline
post #3 of 12 Old 10-25-2003, 11:39 PM
I just adjusted my 03-650 and I had two shims in it. I have 750 mi on it and I took both shims out and put a Black spring in. Now the quad runs well but when I stop and idle in drive the cvt squeals. I think the belt needs a small shim. Or it could wear in over time.
Bandit is offline
post #4 of 12 Old 10-26-2003, 06:15 AM
KISSSOFDEATH's Avatar
Bandit, mine did this too. It is just a little tight and will be fine.
Actually the squeal is a reminder that if we are idleing for an extended period of time we should put it in neutral. As a rule of thumb, if Im going to be stopped with engine running for more than 15 sec I always put mine in neutral.
KISSSOFDEATH is offline
post #5 of 12 Old 10-29-2003, 05:41 AM
Mikey V's Avatar
Sarge-- Kaw. lists 3 for the P-650. There is a forth shim listed in the P-360 parts fiche. They range from .8 MM to 1.4MM, I believe. You should be able to find the numbers on www.buykawasaki,com
2008 BF750i- Cool in Camo
2007 Can Am 800 Gone but never forgotten
11 HD Electra-Glide Ultra Classic for cruisin'
05 CRF450X- woods missile --for sale
"Everytime I start thinking the world is all bad, I see some people on motorcycles, it makes me take another look" Steve McQueen 1970
Mikey V is offline
post #6 of 12 Old 10-29-2003, 12:16 PM
Here you go:
Shims
KVF650-A2
Ref# Part# Description
92026 92026-1565 SPACER,T= 1.00
92026A 92026-1569 SPACER,T= .60
92026B 92026-1570 SPACER,T= 1.40
92026C 92026-1617 SPACER,T= 0.8
Goggleyed is offline
post #7 of 12 Old 10-29-2003, 12:47 PM
Mikey V's Avatar
I was close, huh? I forgot about the .6MM shim :roll:
Mikey V is offline
post #8 of 12 Old 10-30-2003, 08:16 AM
For whatever reason, my P650 doesn't like much shim. With the stock 650 belt I was running no shims & it was perfect. When I installed the 700 belt, I decided to start with the 1mm shim. That has me out of spec loose by about 1 mm so I'm dropping down to the .6mm shim. Hopefully that will put me on the low end of the spec.
post #9 of 12 Old 11-11-2003, 07:32 PM
man i realy want to thank yall alot for the info and part # . got a few shims and i finely got time to try and adjust the belt .Well i went to nyrocs site to get some tek tips guess what . does anybody rember the belt width and defletion. many thanks frank
obx650 is offline
post #10 of 12 Old 11-12-2003, 07:42 AM
obx650,
According to Nyroc's instructions (I kept a hard copy, thank goodness), the P650 belt deflection should be between .87 inches and 1.06 inches (22mm and 27mm). Nyroc also said for each .004 inches (.1mm) of shim thickness that is removed, the belt deflection decreases about .051 inches (1.3mm).
Good luck and happy trails...
2007 KFX 730 (sold)
Happy trails...
belt adjustment 2003 650 prairie
belt shims
brute force 650 shims
brute force belt shim
kawasaki 650 belt shims
kawasaki brute 650 clutch shims parts
kawasaki brute force 650 shim replacement 2007
kawasaki prairie 650 shim part number
kawasaki prarie 650 shims ajustment
prairie 650 belt adjustment
prairie 650 shims
prairie 650 standard shims
shim location kawasaki 650 prarie
Where can i buy clutch shims for belt adjustments? wheelie_king Kawasaki Brute Force/Prairie/Bayou 12 01-06-2009 05:15 AM
Belt Deflection and shims Derek Kawasaki Brute Force/Prairie/Bayou 9 06-23-2005 11:30 AM
New Belt for P650 Sarge Kawasaki Brute Force/Prairie/Bayou 2 05-03-2005 06:17 PM
P650 belt Sarge Kawasaki Brute Force/Prairie/Bayou 9 12-02-2004 07:49 AM
Shims for belt adjustment bud Kawasaki Brute Force/Prairie/Bayou 2 10-21-2004 02:02 PM
