plastic fender repair - Kawasaki ATV Forum
post #1 of 8 Old 09-22-2004, 02:07 PM Thread Starter
I think that I read somewhere mabey Nyrocs website about using Goop and used dryer sheets to repair cracked fenders.Anyone remember this or tried it? Thanks for any help.
P.S. where do you buy it ?
Does anyone know where I can buy realtree hardwoods duct tape?
bilt4speedP700 is offline
post #2 of 8 Old 09-22-2004, 02:14 PM
I repaired a crack with Gorrilla Glue and a patch cut from a plastic anti freeze bottle. So far survived a trip to Utah and Colo mountains, all the way up to 14,000 feet and 35 degrees.
Sarge
Sarge is offline
post #3 of 8 Old 09-22-2004, 04:52 PM
woodman's Avatar
I've heard of using Goop and mesh drywall tape
2014 750 Brute Force EPS - Stage 3 Elkas - 26" Kenda Bear Claw HTR - Rox risers with Fly fatbars - D2 overfenders - 1.5" wheel spacers - Aluminum Products skid plates and A arm guards - Dalton plain purple secondary spring and Orange/blue primary spring - Prothane polyurethane sway bar bushings
2016 Kawasaki Versys 1000
03 P650 - sold
image url
woodman is offline
post #4 of 8 Old 09-22-2004, 08:44 PM Thread Starter
Thought of using fiberglass and the goop, Or should I just use glass mat and resin
? I am almost sure I read somewhere that someone used dryer sheets and goop. I have all the stuff either way just wanted an opinion before I commit.
post #5 of 8 Old 09-22-2004, 09:44 PM
Joebear's Avatar
FRANKENSTEIN!
The best way is to stitch it up! I wrote an article at www.quads.ca under the technical articles. It is very very sturdy just like new plastic. My son has rolled his quad twice and not damaged it. The front plastic was in 4 pieces when I started with it. It is a little time consuming and and leaves the stitches showing on top but overall it is well worth the effort!! The large holes in the picture are from the previous owners repair with rivets and metal.
SMILE!!
02 665 with TRP trail kit 11-1 pistons and trail cams, MUZZY full system, Dyna CDI, 12 hole airbox mod, xover intakes, UNI filter, VFORCE JOHN clutch, 27"XTR's, Hi Lifter lift kit, Warn Winch, A few other custom accessories.
Joebear is offline
post #6 of 8 Old 09-22-2004, 09:53 PM
Looks like battle scars.
MuddyArkie is offline
post #7 of 8 Old 09-23-2004, 09:47 PM
Joebear's Avatar
Has anyone tried this?
Joebear is offline
post #8 of 8 Old 09-24-2004, 05:00 PM Thread Starter
I tried the used dryer sheets and the goop but first I used superglue to hold it in place .If using goop you need somthing like glass mat to hold it from just running off.It looks like it will work well so far.Time will tell when it gets cold and smacked by stuff if it holds or not .
Plastic Repair...or new look... KTM265 Kawasaki Brute Force/Prairie/Bayou 4 03-18-2013 06:57 AM
black plastic repair Ross 650 Kawasaki Brute Force/Prairie/Bayou 16 03-27-2007 04:36 PM
Plastic repair! Andycyprus Kawasaki KFX700 V-Force 1 06-09-2005 03:54 AM
Plastic Repair Joebear Kawasaki Brute Force/Prairie/Bayou 2 03-30-2004 07:27 PM
plastic repair vforcejeff Kawasaki KFX700 V-Force 3 03-29-2004 03:08 PM
