leaking oil from rear drive shaft - Kawasaki ATV Forum
post #1 of 9 Old 01-04-2005, 05:54 PM Thread Starter
My Brute is leaking oil around the seal where the rear drive shaft comes out of the engine. I thought I had heard someone else here say they had this problem. I am going riding in WV next week and will not be able to have it fixed until after i get back. I am wondering how common this has been.
MUDMAN RX is offline
post #2 of 9 Old 01-07-2005, 08:16 AM Thread Starter
bump!
post #3 of 9 Old 01-09-2005, 04:51 PM
I was the one who posted this in the past. You are the first person other than myself having this leak. All I can say is get it ordered, it took almost 3 weeks to get the new seal in.
tommy33 is offline
post #4 of 9 Old 05-04-2011, 07:10 PM
I have this problem right now, it just started, how does this happen? Is it a hard job to replace?
blackbrut7 is offline
post #5 of 9 Old 05-04-2011, 07:40 PM
its the rear main seal its a supposed very common problem, kawi updated this part so when you order/get one get the 2012 seal, its kinda a pain but take the 3 bolts that hold the rear dif in place and just pull it backwards until you can pull the driveshaft out, pull it out, then take a flathead put it on the outside of one side of the seal hit it til it cocks the seal off to one side. then take a pick tool or a fine flathead and go to the opposite side that its sticking up now and try to get behind it to pull it out. pull it out then wipe the dirt and oil from the housing, pop the new one in til its flush, reconnect everything, boom your done.
oh ya make sure you drain the oil first.
hfdbuck09 is offline
post #6 of 9 Old 05-05-2011, 06:38 AM
I had to replace mine. It's pretty simple. There's no reason to unbolt the rear diff. All you have to do is compress the drive shaft a little bit and it'll pop right off the output shaft. DO NOT scratch or knick the machined race where the seal goes in the case. If you use those metal car ramps, it makes it pretty easy to get under there.
Mine went out when I got a little too aggressive with the powerwasher. Brute was covered in 2" of cement like mud.
09 Brute Force 750i
Evanrude is offline
post #7 of 9 Old 05-05-2011, 07:54 AM
Feedback Score: 3 reviews
rdm531's Avatar
i have seen the shafts almost frozen together, an have to really work on getting them to compress, be sure to clean an grease the splines good when you go back togrther. i ride mud an water mostly so i drilled the female splines an installed grease zerks on both front an rear
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #8 of 9 Old 05-05-2011, 08:19 AM
Quote:
Mine must have came apart easy because it only had about 450 miles on it
But yes, definitely grease the splines as you said.
09 Brute Force 750i
Evanrude is offline
post #9 of 9 Old 05-05-2011, 08:21 AM
thats the reason i said unbolt the diff cause mine is frozen up. i might have to use your idea about the zerks, i got them everywhere else mine as well do some there
99 kawaski leaking out rear drive shaft
atv leaking oil
driveshaft brush leaking
front drive shaft seal on can am commander is leaking
how to replace shaft oil on kawasaki concourse
kawasaki concourse shaft problem
leaking grease around drive shaft
leaking oil from rear drive shaft on kwaski bayou
oil leak in kawasaki bayou drive shaft
oil leaking from rear of atv
stop the oil leak on propellor shaft of a bayou
why does my 1995 kawasaki bayou leak from driveshaft
why is my drive shaft leaking by the rear
Need rear drive shaft assm speedy81304_KVF700 Wanted 1 01-18-2008 11:17 PM
drive shaft bubbasoffroad2 Wanted 8 12-14-2007 07:57 PM
KAWASAKI PRAIRIE 700 4X4 2004 REAR DRIVE SHAFT CASE NEW! Prairie Under Pressure For Sale 4 12-27-2006 10:47 AM
Leaking front drive shaft seals Footy Kawasaki Brute Force/Prairie/Bayou 3 10-06-2006 03:54 PM
front drive cv shaft JOEMIDDP700 Kawasaki Brute Force/Prairie/Bayou 5 05-31-2004 08:22 AM
