Remove water from engine oil - Kawasaki ATV Forum
post #1 of 6 Old 01-17-2005, 09:19 PM Thread Starter
If a engine ever gets water in it's oil (Milky color I know) what is the best way to remove it? I know you can do multiple oil changes, but I've also heard that you can drain all the oil and then flush it w/ Diesel Fuel to get any remaining water. I know you don't run it w/ the Diesel fuel in it... just pour it and then drain it out. Is their anything better than Diesel fuel to Use? Kerosene?
Thanks
BamaBrute is offline
post #2 of 6 Old 01-17-2005, 09:27 PM
Joebear's Avatar
Only way I have heard of is to keep running oil through it. Fill run for a bit drain. repeat untill all is gone. Buy several cheap filters to do this. Change the filter every time. Some people save their old filters for this reason. Just put them up to drain till they are needed. Pain in the ... but the best way to do it! Do a search on here for oil filters and you will find a x reference to some cheap brands! Once you are done I would run a good filter though!
SMILE!!
02 665 with TRP trail kit 11-1 pistons and trail cams, MUZZY full system, Dyna CDI, 12 hole airbox mod, xover intakes, UNI filter, VFORCE JOHN clutch, 27"XTR's, Hi Lifter lift kit, Warn Winch, A few other custom accessories.
Joebear is offline
post #3 of 6 Old 01-17-2005, 09:31 PM
bartlettracing's Avatar
fill it to the top with Kerosene .... turn it over a few times with the plugs out ... drain and fill with cheap oil ....... run till warmed up ... change oil and its done /
10 speed pedal bike
bartlettracing is offline
post #4 of 6 Old 01-18-2005, 06:52 AM
DOA
Can you use kerosene in the rear ends?
We just had water in my buddies rearend, the oil didn't seem to take it out very well, we ended up puting it by the wood stove and using a little hair dryer action with the plugs out for a day or so to let it evaporate some. Seem to help, we didn't have any extra oil, just enough for two changes.
I think I read that kerosene can hurt rear ends, is this true, we were wondering about that?
03/650Prairie/camo
DOA is offline
post #5 of 6 Old 01-18-2005, 07:19 AM
yes you can use it in the rear also .... fill it full , bounce it around by hand a little while ,drain ... fill it with the proper oil, run it for 10 min .... change and be done
note your not leaving it in there for enuf time to effect any seals ect ..
10 speed pedal bike
post #6 of 6 Old 01-18-2005, 06:19 PM
scott650's Avatar
Quote:
thats good to know i will have to remember that. thats two new things i learned today i'm do for the day my head hurts thanks bartlettracing.
04 700 V
FPS 730
Muzzy
EPI Maroon
Elka's
Vforcejohn's stage III clutch mod
Lightened secondary
08 Brute Force 750
EFI
scott650 is offline
additive to remove water from engine oil
best way to remove water from engine oil
best way to remove watter from a mororcycle motor
eliminating water from engine
how to get water out of a 750 v-twin engine
how to remove water from engine oil
how to separate motor oil and water
remove moisture from engine oil
remove water from motor oil
removing water from engine oil
removing water from oil in engine
water in motor oil repair
HOW TO REMOVE KEBS ON 08 BF 750? tayznild Kawasaki Brute Force/Prairie/Bayou 5 04-25-2008 11:33 AM
Evans,Water Wetter, or Engine Ice???? SlvrBrute Kawasaki Brute Force/Prairie/Bayou 4 10-26-2007 07:58 PM
how to remove clutches.... looney69z28 Kawasaki Brute Force/Prairie/Bayou 1 03-19-2005 03:38 PM
Running just water to cool engine? T3ch_N9ne Kawasaki KFX700 V-Force 8 01-03-2005 11:51 AM
sold please remove Rkhard For Sale 2 04-11-2004 06:23 AM
