Still won't crank
This is a discussion on Still won't crank within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Okay, for a quick recap I sunk my Brute a few days ago. I've had my plugs out for a couple days now trying to ...
Old 01-20-2005, 08:53 AM   #1
View BamaBrute's Photo Gallery(0)
Default
Okay, for a quick recap I sunk my Brute a few days ago. I've had my plugs out for a couple days now trying to let the cylinders dry out. I've pull crank it several times w/ the plugs out to try and force any remaining water out the spark plug holes. I have a bad battery on my Brute and it's dead and even if I charge it fully it'll only crank it over a few times before dying again.
I put the plugs back in today and I still won't even think about cranking. I choked it and didn't give it any gas. I turned over fine, it just would never fire off. Could the plugs be shot?
Any thing else I can do to get it to fire off if it still won't crank after I replace the plugs? Only a small amount of water got into the cylinders and the engine was off when the water got in.
BamaBrute is offline   Reply With Quote
Old 01-20-2005, 09:04 AM   #2
View EuroBrute's Photo Gallery(0)
Default
Hi
remove plugs from the cylinder.
attach one plug to the lead and hold it against the cylinder block " earthing the plug"
crank the engine and look if the plug sparks.
do this with both leads.
If there is no spark then its an electrical problem ie ignition
Hope this helps
TOM
EuroBrute is offline   Reply With Quote
Old 01-21-2005, 02:09 AM   #3
View MuddyArkie's Photo Gallery(0)
Default
Did you drain the carbs? Water will just set in the bowls and it sure won't run with that.
MuddyArkie is offline   Reply With Quote
Old 01-22-2005, 07:25 AM   #4
View looney69z28's Photo Gallery(0)
Default
hey, you are gonna wanna check and change your oil and oil filter as well. even if the engine was off when it went in, water will get anywhere. i buried mine and had to change the oil 5 times to get all the water out. you will also want to check your belt housing for water, depending on how deep you sunk it, water may have gotten in through the vent and is now just sitting in the bottom of the cover. cleaning/drying out the carbs would be a good idea, i cannot hurt. i would just go ahead and get new plugs, and a new battery while your at it... just make sure that if there is water in ANY PART of the motor or drivetrain, do not let it sit to "air out" you should try to get the water out asap. when you do get it started, let it idle for about 5 minutes, then take it on a NICE SMOOTH ride, nothing hard or intense, just something to rev the motor up, and dry it out.
you may want to check your other fluids as well, like your differentials, coolant, and anything else where water may have gotten.
dunking a machine is not an uncommon thing, but with the proper maintenace and precautions, your machine will be just fine.
PS- mine would not start for a good half hour that involved taking the plugs out, drying them out, tying again, and repeating the vicious cycle again. you just gotta work the water out.
looney69z28 is offline   Reply With Quote
You may not post new threads
You may not post replies
crank 700 or 750 brute 730 Wanted 0 05-28-2009 02:32 PM
how do you get the crank out camo650 Kawasaki KFX700 V-Force 8 12-09-2008 09:36 PM
crank for a 750 bf ford4442003 Kawasaki Brute Force/Prairie/Bayou 2 02-25-2008 12:40 PM
Need a CRANK BAD Kawy Wanted 2 10-08-2007 11:09 AM
650 with 750 crank? Whitey Kawasaki Brute Force/Prairie/Bayou 10 08-06-2007 08:51 AM
