Got my Water logged Brute to crank.
This is a discussion on Got my Water logged Brute to crank. within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Well after changing the plugs and giving my battery a good charge it cranked off. I was told by a Mechanic to put some Marvels ...
Old 01-22-2005, 02:06 PM   #1
View BamaBrute's Photo Gallery(0)
Default
Well after changing the plugs and giving my battery a good charge it cranked off. I was told by a Mechanic to put some Marvels Mystery oil into the Cylinders to stop any rust that the water had done to the rings. I have always heard good things about that stuff.
I had the airbox off the carbs so I poured a little bit into each carb. Just enough to bog it down a little and it smoked pretty good. It says to run some in your gas to, so I'll probably do that.
I'm 99.9% sure my oil has no water in it. It looks brand new and is good and clear. I'm gonna change it and the filter anyway though. I'll even flush it w/ Kerosene just to make sure no water is in their.
I also noticed that the vent lines from both gearboxes run into the handlebar pod. My Brute never got in deeper than the fenders since It floats so I know my gearbox oils should be okay. I've snorkled my Carb vent lines up their as well and the Carbs didn't appear to have any water in them when I drained them.
I think all in all I just ruined a set of plugs and wasted some time. Could have been worse I guess.
BamaBrute is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 01-22-2005, 05:43 PM   #2
V10KLZZ71S's Avatar
View V10KLZZ71S's Photo Gallery(0)
Default
Good news Bama, i sunk my prairie in the mississippi river once.went up to the bars,the motor died,i pushed it up to some higher ground and it cranked back up and i tried to take off and the belt slipped [only time it ever slipped] so i put it in nuetral and revved it up a couple of times and took off, all was well.I go in water all the time up to the headlights and have no problems.
Life should not be a journey to the grave with the intention of arriving safely in an attractive, well preserved body, but rather skid in sideways,beer in one hand, body thoroughly used up, totaly worn out and screaming......Damn, what a ride!
ATVCCS UTILITY CLASS #963
06 Aztec Red 700 Prairie Dyna CDI, 27" 589'S, MotoSport Alloys Telluride's. [SOLD ALSO DAMN]
04 Green P700 Dyna,DJ needles on 4th notch, 134/138 DJ Jetting,Carb slide vacuum holes enlarged, Mild head porting, Napa hose mod, HMF Penland Full system, Epi pink primary, Epi red secondary, 3000# Warn, 27" 589's,HL lift kit, ODI grips.[SIZE=7][COLOR=red]SOLD!!! I will miss her.
V10KLZZ71S is offline   Reply With Quote
Bookmarks
You may not post new threads
You may not post replies
brute skipping across top of water/mud zukitough Member Pictures & Movies 44 12-15-2007 04:20 PM
Brute Force Crank Bearing JAKE JANACEK Kawasaki Brute Force/Prairie/Bayou 8 06-20-2005 12:54 PM
Brute Bogging Down in Deep water 05BrutePower Kawasaki Brute Force/Prairie/Bayou 3 01-01-2005 02:02 PM
Sputter in water on Brute bbertram Kawasaki Brute Force/Prairie/Bayou 0 11-07-2004 03:28 PM
Staying Logged in? BlueBlaster01 News/Support/Feedback 5 02-15-2003 08:50 PM
