prairie 650 4X4 trouble - Kawasaki ATV Forum
post #1 of 4 Old 07-26-2005, 03:41 PM Thread Starter
I have an 03 650 P and it is stuck in 4 wheel drive. The dash says 2wd even when the switch is in 4wd. I think it is an electrical problem. There is no bumping or grinding noises coming from the front end and the machine turns normal for 4wd. When I notice the 2wd on the dash, I had been going through water, nothing high enough to damage anything, but I know I didn't do anything to hurt it mechanically. Is is possible that something got wet? Any suggestions on where to start trouble shooting.
detes55 is offline
post #2 of 4 Old 07-26-2005, 04:49 PM
Feedback Score: 5 reviews
vtprairie03's Avatar
i had something similiar happen to mine. make sure that the 2wd/4wd switch is making contact. the rubber around the switch will dryrot and let moisture in corroding your connection. take the switch apart and clean it up good with contact cleaner and sqirt some dielectric grease on it. it fixed mine for about 3 months but the oxidation was so bad i had to just replace the switch. its only about 30bucks so not bad. im not saying thats what it is but its somewhere to start looking, plus its probably good to clean it up anyway from time to time.
FST 730
LTE DUALS
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
2007 kfx 90
120cc powroll bbk
cam'd
two brothers full exhaust
ac racing nerfs
rath racing front and rear bumper
jb racing +2 a arms
previous motors..
fst 765-stage 3 cams-full porting-lte duals
amr 800-ported big valve heads-x3 cams- lte duals..
vtprairie03 is offline
post #3 of 4 Old 07-28-2005, 04:42 AM
I had a bad switch on ours too. Was stuck in 2wd wouldn't switch to 4wd for anything, display didn't change either though. New switch took care of the problem.
squirrel is offline
post #4 of 4 Old 07-28-2005, 12:52 PM Thread Starter
I traced all the wires and made sure all the connections were good, only to find out that for some reason the fuse for the KBEC was only letting 5 to 6 volts flow through and not 12. Two dealer ships told me that the 4X4 connection did not have a fuse. LIARS
After replacing that fuse the 4X4 worked fine. So the acturator must run off the same power as the KBEC controller. I don't know why the KBEC kept working on that low of voltage.
Thought I'd post this in case any one else comes across the same problem.
detes55 is offline
2003 kawasaki prairie 650
2003 kawasaki prairie 650 4x4 problems
2003 kawasaki prairie 650 4x4 switch
650 prarie kawasaki teryx 4wd switch
kawasaki 650 fourwheeler stuck in low
kawasaki prairie 650 4x4 not working
kawasaki prairie 650 4x4 troubleshooting
kawasaki prairie 650 stuck in 4x4
kawasaki prarie 650 stuck in 4wd
Cam Trouble 450Duner Kawasaki KFX450/KFX400 9 05-17-2008 12:11 AM
having trouble please help crazyorange Kawasaki KFX700 V-Force 25 06-26-2007 12:15 AM
Have some trouble.. any HELP??? cole2676 Kawasaki KFX700 V-Force 15 03-27-2007 06:59 PM
ktm in trouble again bartlettracing Kawasaki KFX700 V-Force 4 01-09-2005 09:40 AM
Have some trouble.. any HELP??? cole2676 For Sale 0 12-31-1969 07:00 PM
