Key off battery drain - Kawasaki ATV Forum
post #1 of 19 Old 11-13-2006, 05:06 AM Thread Starter
The last couple times I attempt to start my 06 BF750 the battery is too drained to start it. After charging, the wheeler starts and puts out 13-14 volts at idle and higher RPM. I placed an amp meter between the battery and cable and it registers about 12 amps with the key off. There are no aftermarket items attached. Any idea on what items to start disconnecting to track this down? Does all power go through the main soenoid or does the controller pull power even if the solenoid is working properly?
lukewarm is offline
post #2 of 19 Old 11-13-2006, 06:37 PM
best thing to do is check your. volt/reg. if it has a short to ground that would be it. it would back feed. and at idle thats high. it should be about 12vs and peak out at 14v at 4k rpm. if your peaking out at idle then i would say check your volt/reg.
I'll look in my factory manual for the testing on the volt/reg. also ill thing of some other problems that it might be. i'll pm you soon as i can.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline
post #3 of 19 Old 11-13-2006, 06:59 PM
Prairie Under Pressure's Avatar
[/b]
May have a bad battery, I did and I just replaced it. Warrenty doesnt cover it unless you are still under the 6 month factory one.
2007 Cadilliac Escalade ESV 403 hp 6 speed trans
2003 Dodge Hemi Ram 4x4 Quad cab
1996 Dodge Cummins turbo Diesel 280HP 680TQ
2004 Prairie 700
2001 Polaris 500 HO
2009 Honda RancherES 420 4x4
2003 Honda 250EX
2001 Kawaski KX125
2001 Kawasko KX100
2002 KAwasaki KLX125
2004 Carter Talon 150cc GO Cart
2006 50cc R1 Super mini bike
Prairie Under Pressure is offline
post #4 of 19 Old 11-14-2006, 05:33 AM
Is the weather colder and are you not using it a lot? If it's not being used a lot in colder weather, I leave mine plugged to a battery tender. This is the worst time of year for batteries.
Keep us posted
[/b]
dkane3829 is offline
post #5 of 19 Old 11-14-2006, 05:35 AM Thread Starter
Thanks guys.
Speedy, that makes sense. I thought the voltage was pretty high for idle. If you have the test procedure for the regulator, that would be great. What is the best source for a replacement if I need one? Any alternates to buying from the stealer?
lukewarm is offline
post #6 of 19 Old 11-15-2006, 04:59 AM Thread Starter
It is not the voltage regulator. I unplugged it and everything under the seat, one component at a time. It is now registering a 4-5 amp draw. The only thing that changes it is pulling the 30 amp fuse or disconnecting the two wire plug that branches off the positive battery cable just prior to the solenoid connection. Both wires are white with a red stripe.
Does anyone have a schematic that show what components are all fed from this connection?
lukewarm is offline
post #7 of 19 Old 11-15-2006, 05:45 AM
Mikey V's Avatar
[/b]
Check the usual corroded splice in the rear harness, back by the fuel tank filler neck. The last BF750 I saw do this, one regulator wire was corroded in that white plastic splice, taped to the side of the rear (main) harness. The BF750's do ALL kinds of weird things, when the spliced wires corrode. They can start with key "off", inop cooling fan, no start in 4WD mode, the list goes on. You'll need to remove the rear fender(plastic), to access the area, and get to the splice to repair it. It will become obvious why they corrode, when you see where this splice is located---on top of the fuel tank, where the splice sits in the mud thrown on to the top of the tank!
2008 BF750i- Cool in Camo
2007 Can Am 800 Gone but never forgotten
11 HD Electra-Glide Ultra Classic for cruisin'
05 CRF450X- woods missile --for sale
"Everytime I start thinking the world is all bad, I see some people on motorcycles, it makes me take another look" Steve McQueen 1970
Mikey V is offline
post #8 of 19 Old 11-15-2006, 10:37 AM Thread Starter
I thought the 06 models did not have that problem any more.
lukewarm is offline
post #9 of 19 Old 11-15-2006, 11:03 AM
Mikey V's Avatar
[/b]
I don't know if Kaw. actually listened to their dealer techs, or not. Maybe they were upgraded, dunno.
Mikey V is offline
post #10 of 19 Old 11-15-2006, 02:27 PM
My 06" STILL has the rear buss connecter!
Bigmike750BF is offline
2005 kawaski priae 4 wheeler battery draining
4 wheeler battery drain test
atv battery discharges with key off
battery drains after turning atv off
bayou 300 battery drains overnight
can a solenoid drain a battery in a atv
four wheeler battery draining
kawasaki mule drains battery
kawasaki prairie battery drain
kawasaki regulator draining battery
key in off position but battery drains still
what drains a four wheeler battery
what is draining battery on my 4-wheeler
Oil Drain Plug GeneralV Kawasaki KFX700 V-Force 7 02-26-2009 08:09 PM
TO DRAIN TUBE OR NOT TO DRAIN TUBE 700ccMARSHMELLOW Kawasaki KFX700 V-Force 7 10-13-2006 11:49 AM
Oil drain plug? sircrashalot Kawasaki Tecate 4 09-21-2006 04:01 PM
Need new drain plug... 05BrutePower Kawasaki Brute Force/Prairie/Bayou 1 02-17-2005 05:32 PM
CVT drain plug Soggybottomboy Kawasaki Brute Force/Prairie/Bayou 10 10-12-2004 02:04 PM
