4wd not working - Kawasaki ATV Forum
post #1 of 7 Old 02-26-2007, 06:38 PM Thread Starter
05BrutePower's Avatar
My four-wheel drive wont work. Flip the button and it just wont engage. Nothing on the display is indicating a change from 2 to 4 wheel drive either. Thanks in advance
2008 Kawasaki Brute Force 650
Stock-No after market as of yet!
05BrutePower is offline
post #2 of 7 Old 02-26-2007, 06:53 PM
Post
I have seen this problem before. There are electrical connectors under the front fenders. If the connectors pull apart, the switch cannot ground the circuit. Look above each front wheel, they are loosly attached to the frame. Suspension movement unplugs them sometimes.
GEARHEAD is offline
post #3 of 7 Old 03-03-2007, 05:06 PM Thread Starter
I took apart the bus connector under the front fender today and sadered the wires together. I also noticed that my speedometer isnt working. Does this have something to do with the 4 wheel drive? is it all connected to something thats not working? Thanks
post #4 of 7 Old 12-29-2010, 05:45 PM
it will only work if the speedo is working
bolensg-10 is offline
post #5 of 7 Old 12-29-2010, 06:51 PM
Sounds like the speed sensor. This sensor is on the right side, if your sitting on the atv just behind your heel.
The service manual walks you through the tests for this part. I have an 05 Prairie 700 service manual and can send you a link to download if this will help?
dogpile is offline
post #6 of 7 Old 12-29-2010, 06:58 PM
www.ATVPT.com - Service_Manuals
Here is the manual, Im guessing the Brute is very similar. You can use safety pins to slide into the controller wiring harness and a volt meter to do all the checks.
To debug this issue go to section 17-79 and it will walk you through everything. It takes maybe 20minutes.
dogpile is offline
post #7 of 7 Old 01-01-2011, 12:53 PM
i got an 09 and it says it is in 4wd and its is not, it works in reverse and not in high or low
2006 brute force 4 wheel drive not working
2008 brute force 4 wheel drive not working
2008 teryx 4 wheel drive not working
2009 bruteforse 650 4x4 4 weel drive not working
2010 brute force 4wd not working
4 wheel drive doesn't work on a 2005 brute force
750 brute force 4 wheel drive not engaging
kawasaki atv 4 wheel not working
kawasaki prairie 650 4 wheel drive wont work
kawasaki teryx 4wd not working
my speedo and 4 wheel drive wont work on my 05 brute
prairie 4 wheeler 4 wheel drive does not work
tyrex not shifting four wheel drive 2008
4x4 not working davec Kawasaki Brute Force/Prairie/Bayou 9 11-14-2008 06:50 PM
fan not working TSprairie700 Kawasaki Brute Force/Prairie/Bayou 2 05-03-2007 01:11 AM
4x4 not working!! JMcClure Kawasaki Brute Force/Prairie/Bayou 4 02-27-2007 12:08 PM
Working out... KTM265 Club Kawie 11 10-30-2006 08:48 PM
4WD not working sdteb Kawasaki Brute Force/Prairie/Bayou 1 08-29-2004 08:10 PM
