This is a discussion on 4 inch lift for P700 within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; well ok. as my buddy is making parts for my P700 yard worker. im working on making my other of the two bigger and badder. ...
| Kawasaki Brute Force/Prairie/Bayou Kawasaki's strong and reliable utility ATVs |
LinkBack | Thread Tools | Display Modes |
#1 |
well ok. as my buddy is making parts for my P700 yard worker. im working on making my other of the two bigger and badder. I havent seen any p700's with much more then the HL 2 inch kit. so im taking it to the next step 4inchs of lift. in order to clear the new outlaw 31" tires. also I got the Dura Blue rear axle that should be able to handle the stress put on by those big tires. already in the making of getting the rear lifted first. once thats in place then ill match the front. you guys will see it at QUAD FEST IN PA next year.
also I'm in the works of building a new BF840 mud monster with a customer. he wants 10 inches of lift and wants to make 33 inch super swampers. so making hubs to bolt on to the stock hubs in order to bolt up chevy 5 bolt 15 inch wheels. its not my money and thats what he wants. you all know the customer is always right.
2004 RED P700 Trail monster 2" lift kit 1.5" wheel spacers. 28"mudlight XL's 10x12 frts 12x12 rears Amsoil 0w-40 engine oil / Frnt Diff Amsoil 5w-30 rear diff (hydraulic/transmission oil) Water Wetter mixed 25% coolant 75% water Twin air ProFlow filter, Dyno Jet needles Muzzy Full System, Denso Iridium plugs #IU22. "Freebie" Moose Module & 6deg key installed EPI Primary and secondary springs. VFJ stage 3 spider mod, machined secondary. Full set EPI black springs with custom front preload spacers. SOON VFJ crossover INTAKES AND VFJ dyno tuning |
| Sponsored Links | ||
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free! |
#2 |
also I'm in the works of building a new BF840 mud monster with a customer. he wants 10 inches of lift and wants to make 33 inch super swampers. so making hubs to bolt on to the stock hubs in order to bolt up chevy 5 bolt 15 inch wheels. its not my money and thats what he wants. you all know the customer is always right. [/b] Mike Walker made some hubs that mount regular wheels i believe. I know he is running those big swampers on his mule.
05' Prairie FST 730 |
#3 |
yeah i know. how mike did it on the mule project. this customer wants it to look stock. I mean we have to find wheel that look like stock rims. I'm thinking of the cheap wagon wheels. painted gun gray.
as for my lift im being diffrent about my machine i want no one to have something like mine thats why Mike builds his the way he does. right
#4 |
Feedback Score: 1 reviews
I think I know what you are going to do, and I thought about doing this a while ago. Just haven't had the time or money. Then when the 31" outlaw talk started, I wanted to do it even more. The way I figured it, you could get about a 4 inch lift with gorillas for around $1200-$1400 if you fabbed the front a arms and drop brackets for the struts yourself. Not bad considering the gorilla 6 inch is 2500.
#5 |
camo lets just say its going to be under 900 bucks for the lift im making. 700 of it is just in the rear only.
the rest is making a-arm drop brackets and larger cups for the top of the struts. I should be able to just use the oem shafts. just to an outter HD upgrade and rebuild the inners to oem spec. since the outters are the weak link. yeah im going with the 29.5" outlaws on High lifter 12" XL2 rims.when they are ready from high lifter. but i'll be test fitting everything on a set of 30" mudzilla's that a buddy is going to loan me untill the outlaws are out. I know i might need to do some mods for the front tires to clear when turning. I also am looking into moving the front out about 2 inches. by cutting and streaching the frame. and moving the front diff forward 2 inches. I would need to make a long front drive shaft. but dont know yet untill i get it in the works. those 31" outlaws are to skinny. seen them side to side with 29.5's and since i ride more in swampy muddy marshy trails. the wider tires will help it ride on top then sink in.
Back to Top
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 8 1 I/4 INCH AIR BOX MOD | crazyorange | Kawasaki KFX700 V-Force | 15 | 05-16-2007 12:48 PM |
| K&N and 27 inch for BF 750 | EuroBrute | Kawasaki Brute Force/Prairie/Bayou | 1 | 08-01-2005 03:30 AM |
| 1 or 1.5 inch? | bbertram | Kawasaki Brute Force/Prairie/Bayou | 7 | 06-29-2005 12:51 PM |
| wheel spacer, HL Lift Kit, Lift Springs, DG module | Mikeyboy_esq | For Sale | 9 | 03-20-2005 09:41 PM |
| 26 inch outlaws | MUDMAN RX | For Sale | 0 | 10-26-2004 09:08 AM |
Looking for information on other ATV Manufacturers? Head on over to visit our friends on these other forums specializing in the following: Kawasaki ATV - Can-Am ATV - Polaris ATV - Suzuki ATV - Yamaha ATV - Honda ATV - KTM ATV - Yamaha Raptor - Can-am DS450 - Kawasaki KFX 450 - Suzuki LTR 450 |
