flashing between 2x and 4x4
This is a discussion on flashing between 2x and 4x4 within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; hi the problem i got know is on my o5 bf650 the light is flashing between 2 and 4 wheel drive this has happened before ...
Old 08-26-2007, 09:27 AM   #1
View harley1212's Photo Gallery(0)
Default
hi the problem i got know is on my o5 bf650 the light is flashing between 2 and 4 wheel drive this has happened before 3 other times under warrinty now what im wondering if theres a underlying problem that is causing this to happen any thoughts on this
thanks har
harley1212 is offline   Reply With Quote
Old 08-27-2007, 06:58 PM   #2
Kawakvf700's Avatar
View Kawakvf700's Photo Gallery(0) Send a message via MSN to Kawakvf700
Default
thanks har
[/b]
your break engine is dead....
Engine builder
Porting
Machining engine
Valve seat ....
Kawakvf700 is offline   Reply With Quote
Old 08-29-2007, 01:14 PM   #3
Feedback Score: 3 reviews
minimus's Avatar
View minimus's Photo Gallery(0)
Default
There are two actuators engine break and 2wd/4wd. Time the flashing to determine which one is bad.
If its the 2x4 actuator some here have removed the engine break actuator and used it there. Many don't feel the engine break as necessary because you will still have engine breaking down to around 5 mph. This is determined by stall of the primary clutch spring.
Actuator Control System Trouble Shooting,
When the actuator fails, the controller enters failure mode and the indicator light illuminates 2WD, 4WD alternately.
1. If it alternates really fast at .5 seconds on 2wd and .5 seconds on 4wd then the problem is Selectable 2wd/4wd actuator.
2. If it alternates from 2wd/4wd at 1 second intervals, the problem is the Engine Brake Actuator.
3. If it alternates from 2wd/4wd at 2 second intervals, the problem is both the selectable 2wd/4wd actuator and Engine brake actuator.
Brute Force AMR 840, 4X cams, extended rockers, Big Kev's Performance Full race port, +1.5mm intake valves, +1 mm exhaust valves, muzzy pro, 39mm carb, programmable dynatek cdi, triple snorkeled airbox, Boss Noss wet nitrous, JHmachine clutch (RIP JIM)
2010 Polaris 850XP EPS sweet ride for aging bones
minimus is offline   Reply With Quote
Old 08-30-2007, 01:06 AM   #4
Feedback Score: 1 reviews
bb 650's Avatar
View bb 650's Photo Gallery(0)
Default
There also is another Problem it can be that I just had on a Customers bike this week,its a 06 BF750 and it to was flashinf 2wd & 4wd and the code said the engine braking was bad so I replaced it and nothing same deal,so wen threw the book and nothing so it leads back to the Control Box and it was Bad,the is the Black Box beside the CDI Box under the seat,see if you can switch with a buddy to make sure yours isnt bad but this one was and this fixxed the Problem.Hope this can help
06 Brute 650
665 FST
Stage 3 Cams
bb 650 is offline   Reply With Quote
You may not post new threads
You may not post replies
2wd 4wd flashing solved mugsy Kawasaki Brute Force/Prairie/Bayou 3 10-02-2008 09:38 PM
2wd 4wd Light flashing mugsy Kawasaki Brute Force/Prairie/Bayou 2 06-11-2008 05:49 PM
2wd/4wd flashing js198027 Kawasaki Brute Force/Prairie/Bayou 2 06-01-2008 04:47 PM
speedo keeps flashing on and off wheelie_king Kawasaki Brute Force/Prairie/Bayou 6 08-21-2007 07:50 PM
Flashing 2WD/4WD toadmax Kawasaki Brute Force/Prairie/Bayou 21 11-21-2003 07:34 AM
