diff lock - Kawasaki ATV Forum
post #1 of 4 Old 12-29-2007, 06:20 AM Thread Starter
golferbrady's Avatar
has anyone ever adjusted there diff lock mine is very lose and does not work
2002 Kawasaki Prairie DYNATEK CDI BOX ,shimed carbs, pink primary, almond secondary,27 inch gators,jb weld on radiator,two new head gaskets
golferbrady is offline
post #2 of 4 Old 12-29-2007, 09:47 AM
Feedback Score: 3 reviews
sawhead's Avatar
yep,it's very easy...undwer the handle bar cover there's a the diff cable with a aluminum collar on it,loosen the set nut and then just tighten it up to your liking...i think the actual setting should be somewhere around 8-10 lbs. of pull pressure (someone will chime in with the exact pressure)...i just set mine a bit tighter due to my own preference
WOODS RIDING WHEELIE MONSTER
Scrambler 850...bright white/26.5 growlers on black powder coated sportsman xp wheels/steering stabilizer
BF650
...camo/26.5 growlers on black diablos/vfj stage 2/vfj1 primary/vfj4 secondary/pro circuit t4 full exhaust/dyna/steering stabilizer
Kymco MXU 150...green/cdi/2000 rpm clutch work/kenda klaws/douglas blue label wheels
Grizzly 450...blue/27 black diamond xtrs
sawhead is offline
post #3 of 4 Old 12-29-2007, 06:34 PM
Ruttratt's Avatar
yeah it is 7 lbs of pull i used a fish scale put the hook on there and pulled until it read 7 pounds i think about a 1/2-1" away from the grip.
"Ride as if everyone is watching; Talk as if everyone is
listening . . ."
'02 red p650, dyna cdi,Oury grips, epi pink pri. spring, black sec. spring, napa hose mod, Nyroc exhaust mod, Mike Walker oil cooler, custom tow hooks frt. and rear. Epi heavy duty frt. springs, EPI 56 gr.weights, K-bec fork removed, Kimpex rear bumper, 25" outlaw MST.
Ruttratt is offline
post #4 of 4 Old 12-30-2007, 03:49 PM
i adjust my diff every other time i go out. just to make sure its ready to go. since i use it alot. i really need to get another pen-lock. im waiting for my diff plates to wear out that how much i use it. my cable is about 50% worn out. thinking a new one this year. but i'll wait till the adjust ment is almost out of spec. the way i do it is turn in the adjustment on the top all the way in. then go down to the bottom adjustment area. jack up the left side so the left front tire is off the ground but keep the right side on the ground. this is wear my method is diffrent i slowly turn the left tire as i tighten up the adjust ment untill i feel the tire draging on the clutch plates inside. then i back off 1/4 turn then lock it down. then i go to the top adjust ment and fine tune the lever. works everytime for me and i have the same oem diff lock since feb 2004, with 295 hrs and 3218 miles on the machine i use the most. and my diff has never let me down. also you could just follow the book. i run my setup tighter on the specs,
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline
adjusting differential lock 0n kawasaki mule 3010
differential in 2005 3010 mule won't engage
how to get differential lock to work on kawasaki mule 3010
kawasaki mule 3010 differential lite stays on
kawasaki mule 3010 differential lock
kawasaki mule 4wd cable adjustment
kawasaki mule differential adjustment
kawasaki mule differential lock
kawasaki mule differential lock adjustment
kawasaki mule differential lock problem
kawasaki mule differential won't lock
problems with kawasaki mule 3010 differentials
what is the specs for diff lock cable on mule 3010
Adjustment for diff lock? buckshotlb Kawasaki Teryx 0 04-18-2008 07:52 AM
diff lock davezr700 Kawasaki Brute Force/Prairie/Bayou 2 04-04-2007 09:21 PM
4wd diff lock Derek Kawasaki Brute Force/Prairie/Bayou 4 03-16-2005 08:39 PM
front diff lock-up Konanian Kawasaki Brute Force/Prairie/Bayou 18 03-08-2005 07:36 PM
Diff lock cable 589650 Kawasaki Brute Force/Prairie/Bayou 3 09-05-2004 11:02 PM
