check your mounts and also check you diff mounting bolts. under load forwards on the diff it would turn down into the frame under load in rev. it would try to lift up off the frame.
it could also be one of your cv-joints. i had a clicking sound from the front last year and i checked everything found out to be my inner joint. it had a cracked ball cage. witch made it make the cracking sound.
it only did it going forward. but it could be the same for your issue. but first check all mounting bolts.
and you rear engine mount
2004 RED P700 Trail monster
Muzzy Full System,
