Clutch Springs - Kawasaki ATV Forum
post #1 of 2 Old 07-03-2008, 07:27 PM Thread Starter
They Guys looking for some input on clutch spring kits EPI -Dalton? looking for more low to mid with to much top end lost I have Brute Force 650 sra With 26" mud bugs I slip the belt quite often (new belt to )
650babybrute is offline
post #2 of 2 Old 07-03-2008, 07:32 PM
is your belt adjusted right. if not thats your problem you should be able to turn 26" tires with out changing a thing.
when you replaced the belt did you put the old 650 belt in there if so its the wrong one. the new machines run the same belt. for KFX700, KVF700, KFV650SRA, KVF650I, KFV750I. this belt is wider then the old p650 belt.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline
kfv750i atv
lost top end with clutch springs
Clutch springs RIPNROR Kawasaki Teryx 0 03-18-2009 10:53 AM
need HELP!! w/ clutch springs BIGBRUTE31557 Kawasaki KFX700 V-Force 7 02-11-2008 07:42 PM
Where can i Buy Clutch springs? ShiznityZ28 Kawasaki KFX700 V-Force 12 12-21-2007 09:48 AM
Clutch springs did nothing! lager4 Kawasaki Brute Force/Prairie/Bayou 4 07-02-2007 07:30 PM
Looking for clutch springs tanman Wanted 0 04-24-2005 10:12 AM
