how do i wire up my tach. - Kawasaki ATV Forum
post #1 of 5 Old 07-29-2008, 09:14 PM Thread Starter
I have just ordered an auto meter 8,000 RPM White 2-5/8" Pro-Cycle Street Tachometer, how do you hook this up on the machine, it has a 1 and 2 pulse reading, is it easy to hook up or am i going to have to do some cutting and splicing to make it work. i figure i should in stall a tach so i can make clutch adjustments, for the best performance, and i figure i could tune better with tach.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline
post #2 of 5 Old 07-29-2008, 09:51 PM
Feedback Score: 1 reviews
mike650's Avatar
i think you can wrap one of the wires around the plug or something like that. but that tach dont go high enough. these motors red line at 9200rpm with a dyna cdi
2002 prairie 650
Uni airfilter,12 hole mod,Dyna cdi,HMF slip-on,EPI gold primary,750 brute secondary,AC Racing bumper,PRM grab bar,25"GBC dirt commander's(front),25"Maxxis all trak's(rear),Lethal Threat decals,Powermadd handgaurds,skull/flame grips,maltese cross tail light,red led ground effects,mini radiator scoops,chrome piston shift knob,strut brace,handlebar bag and a bunch of other stuff.....665 with stage 2's coming soon
mike650 is offline
post #3 of 5 Old 07-29-2008, 10:13 PM Thread Starter
stock cdi, with moose module and 6deg advance key. i heard 8K is all i would need. 9200 rpms is just over rev, 6800 rpms is peak performance on stock internal engines i thought and they rev to 7800 in stock form.
i could be wrong.
am i going to need to return this when i get it and get a 10K tach.
Muzzy Full System,
post #4 of 5 Old 07-30-2008, 03:47 AM
Feedback Score: 21 reviews
Camo's Avatar
http://www.kawieriders.com/forums/index.ph...mp;#entry231693
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
Torque is quick... Horsepower is fast
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim / VFJ Clutch Weights & Springs
YOU DESERVE A HIGH FIVE... IN THE FACE... WITH A CHAIR
Camo is offline
post #5 of 5 Old 07-30-2008, 10:07 AM Thread Starter
I called up for my order and changed it before i got the wrong tach. i thought all i would need is an 8k tach I now got a 10K tach here it is.
Features:
Large 5" dial face
0 to 10,000 RPM range
Vibration proof air core meter design
Internal settings for 2, 4, 6 and 8 cylinder engines
Pointer return-to-zero feature
Adjustable swivel mounting foot for mounting at any angle
Benefits:
Incandescent back lighting avoids uneven, hot spots for better night visibility
Highly visible bright red pointer for quick view
Modern DIS ignition applications are covered by the 2 cylinder setting
Shift light can be repositioned around tachometer body for best viewing angle
the sunpro super tach 3. now here the thing, I the tech said its not water proof, and i would have to seal it with silcon and still thats not a 100% water proofing. so i guess ill have to try to keep it from getting wet.
I wanted a 5" so its easy to see and read and it will look cool i think with a monster tach sitting up in front of my handle bars. and it was 100.00 bucks from jegs.
Muzzy Full System,
hooking up a tach to a 4 cylinder motorcycle engine
how to build tachometer for atv
how to hook up a tachometer to a honda atv
how to hook up a tachometer to two cylinder motorcycle
how to hook up motorcycle tach
how to hook up tach on cylinder engine
how to make a tachometer work on 2 cylinder
how to wire a super tach 2 on atv
how to wire car tachometer to work on v-twin motorcyle
how to wire up a tachometer
where do i hook up a tachometer on my brute force
where do the wires on my tach go
wiring up a tachometer sunpro super tach 2 to a motorcycle
WHICH WIRE TO GET TACH SIGNAL dillonperformance Kawasaki Brute Force/Prairie/Bayou 2 12-02-2008 05:14 AM
best wire to get a tach signal dillonperformance Kawasaki KFX700 V-Force 0 12-01-2008 10:22 AM
Tach Wire Camo Kawasaki KFX700 V-Force 27 06-23-2008 07:47 AM
Hot Wire Fan????? OrangeForce Kawasaki KFX700 V-Force 12 04-25-2005 05:33 PM
Tach and tach mount pics shaneb Kawasaki KFX700 V-Force 11 06-04-2003 09:39 AM
