09-12-2008, 04:43 PM
#1
I've got my quad tore down and was gonna change the coolant and put an oil cooler on and wonder what would be a better coolant. I race and play around during the winter so I want something thing that would keep it cool and hold up during the winter. Would it be better to run a totally different coolant or just put an additive in it? And is there any special way to flush the old coolant out?
Thanks for your help
2007 Team Green Brute Force 650, Team Green Powdercoated Frame, 12 1" Holes, Twin Air Filter, Maxxis AllTraks Mounted on OMF Beadlocks, Custom Heavy Duty Front Bumper, Custom Front Brace,Custom Rear Grab Bar, Racks Removed, Power Madd Handguards, Pro Armor Tether Switch, Oury Grips, Moose Racing Brake Levers, HMF Penland Pro Exhaust, KEBC forks removed, manual fan switch, Progressive Front Springs
2009 Sponsors: Twin Air, Motoxsupport, Engine Ice, Amsoil, ASV
"Pin It to Win It"
09-12-2008, 06:32 PM
#2
Prestone 50/50 premixed, Works great, and fairly cheap. Work all year round.
I used the shop vac and sucked out all the old coolant from the motor.
Don't buy too much into the more expensive stuff. I would only consider them for racing when you don't want to stop and are willing to risk your motor for the finish. They normally just have much higher boiling points. so they stay in the motor instead of boiling over and spitting out. but at the cost per gallon, stick with the prestone.
I have 3 gallons of Evans sitting on my shelf that I've never used because of fear that it would hide problems that I had..
Home of the World's Slowest and now Ugliest V-Force - Unofficial DragstripTime 4.2 - I was in front of 700mud filming him when he ran 4.4
PK, Inc - Stealing others Ideas since 1999!!</span>
Building the Ultimate Trail Machine: FST 715 BBK, Stage 2.5 cams, Twinair power Flo with 15 holes in airbox. Herrmann Racing A-arms and Anti-Vibe Steering Stem, Fluidyne Radiator, Hiper Wheels with Maxxis Razr2 tires. Fasst Flex Bars, Cycra Pro-Bend Handguards, Hardkor Front Hubs. Honda rear Hubs. AC Racing Wide Grab Bar, IMS Pegs, Heel Guard and Nerfs, Gas Tank. FST CDI, Elka Elite Front & Rear Shocks, 3/4 PRM Skids, THANK YOU FST - Maier Black Plastics , Muzy out - Muzzy Pro in.
On the way: Ultimate Trail and Race Carb Setup
Wishlist: Precision Stabilizer
<span style="color:#000000">Keeping it stupid: 25HP shot of NOS
'08 KFX 700 - The one above looks like a pretzel.
09-12-2008, 07:07 PM
#3
Feedback Score: 3 reviews
I recently started using Evans b/c after I installed my 800cc BBK I started having a problem with regular coolant disappearing (boiling off I think). Since I added the Evans coolant, the problem is gone... so I'll stick to Evans. To use evans, you have to COMPLETELY DRAIN ALL REGULAR COOLANT before you install it. Evan's is waterless, so it don't mix with regular coolant or water. Evan's sells some stuff to flush your motor, but I skipped on buying it...instead, I removed all hoses and left them open to dry for about 4 days or so.
On a side note, I have raced my Prairies/Twin Peaks in dozens of XC races and some drag races too (before and after my 800 motor) and my motor has never overheated (except once when I sprung a leak in my old P650's radiator and lost all of my coolant during the Maxxis 6 hour race). Keep in mind that I have had an oil cooler (Mike Walker's) installed on my motor for a few years now (before I installed the 800 BBK). When I used regular coolant, I always had some purple ice additive (it is the same stuff as water wetter). So I don't think Evans is necessary for most motors...unless you have an 800cc BBK and you start having disappearing coolant issues like mine did.
Happy trails...
2007 KFX 730
2004 Twin Peaks 700 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
09-12-2008, 09:23 PM
#4
A Kawi tech advised do not use automotive antifreeze so I use Honda coolant with a little Redline additive.
09-13-2008, 06:18 AM
#5
Feedback Score: 5 reviews
evans coolant here.. ever since i put the bbk in .. and ive never had a problem...
FST 730
LTE DUALS
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
2007 kfx 90
120cc powroll bbk
cam'd
two brothers full exhaust
ac racing nerfs
rath racing front and rear bumper
jb racing +2 a arms
previous motors..
fst 765-stage 3 cams-full porting-lte duals
amr 800-ported big valve heads-x3 cams- lte duals..
09-13-2008, 02:17 PM
#6
Feedback Score: 20 reviews
Why do Kawasaki tech's advised do not use automotive antifreeze? My local dealer has told me the same thing.
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
09-13-2008, 02:22 PM
#7
Feedback Score: 8 reviews
I have 3 gallons of Evans sitting on my shelf that I've never used because of fear that it would hide problems that I had.. [/b]
Do you want to sell your Evens coolant?
Officiallywas one of the fastest Prairies in the world
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,AMR ported intakes,programmable Dyna,30 shot of Boon,Brute Force Flywheel,stock carbs,stock exhaust,Flexx bars,Rox Risers,ODI grips,Tusk Dozer plow,ECT.
AMR 330 347 6800
09-13-2008, 08:43 PM
#8
Has anybody ever used Engine Ice? I seen it on rockymountainatv's website and didnt know how well it worked, if not im just gonna use prestone 50/50 and add some water wetter to it.
"Pin It to Win It"
09-14-2008, 04:02 AM
#9
[/b]
I would like to know that too.
2002 665 Prairie
FPS 12:1 pistons
FST Stage II Cams
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton weights
VFJ Springs
Other stuff
09-14-2008, 06:17 AM
#10
[/b]
tsprairie700 uses it in his bbk..... if your running a stock machine it would be a good choice... if you have money invested in your motor like some do on here.. i believe the evans coolant is a better choice.. the boiling point is well over 400degrees so incase something was to ever happen to your internals to cause it to heat up over normal running temps the evans is going to prevent it from boiling out... yeah its expensive but id rather be safe then sorry.....
FST 730
LTE DUALS
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
2007 kfx 90
120cc powroll bbk
cam'd
ac racing nerfs
jb racing +2 a arms
previous motors..
| Search tags for this page |
2008 kawasaki quad where do you put coolant, best coolant for kawasaki 650 workhorse 2002 model, can i put regul;ar collant in my atv, can i use regular car coolant in kawasaki teryx, can you put car coolant in your teryx, coolant for brute force 650, how much coolant does a kawasaki 400 bayou hold, how much coolant does a kawasaki prairie 650 hold, how much oil and anti freeze does a 2008 kawasaki teryx take?, kawasaki teryx coolant. how to put it in, teryx 750 where do you add coolant, what type of coolant kawasaki 650 workhorse 2002, where to put coolant in 2008 teryx
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
» » Other Sites
