Old 10-19-2008, 06:07 PM   #1
View abruces's Photo Gallery(0)
Default
Im working on a 03' Prairie 650, there was a few people that worked on it before me and they had the timing set wrong. Im comfused about what marks on the flywheel need to be in sync with what marks on the cam gear. I've tried it many different way's and the valves eather hit, or it does nothing. Ive heard that you also need to set the rear cylinder first, and set the front at 270, so how do i tell i went 270. Any direction in this matter would be really helpfull since im kinda under the gun, and dont have time for a manual to get here, Thanks in advance!
abruces is offline   Reply With Quote
Old 10-20-2008, 01:07 AM   #2
Feedback Score: 3 reviews
Mikeyboy_esq's Avatar
View Mikeyboy_esq's Photo Gallery(13)
Lightbulb
If you look under the TECH TIPS section on Nyroc's website, you will find a very good article written by DWB on how he installed cams on his P700. clicky
In a nutshell, turn one cylinder to TDC and install the cam making sure the arrow on the cam sprocket is pointing straight up...after you finish installing that cam/head, then you turn the motor 270 degrees to reach TDC of the other cylinder and then install that cam. Make sure you put the REAR cam in the REAR head!!! The rear cam should have a groove on it...see the article for more info.
Happy trails...
2007 KFX 730
2004 Twin Peaks 700 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
Mikeyboy_esq is offline   Reply With Quote
Old 10-20-2008, 07:22 AM   #3
Supporting Vendor
Feedback Score: 8 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
Here's the Fool Proof way to find 270.
270* = 3/4 of THE ENGINE'S ROTATION.
So if the rear cyl at TDC is 12:00 position. turn the crank CLOCKWISE 3/4 of a turn until it gets to the 9:00 position.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
VFORCEJOHN is offline   Reply With Quote
Old 10-20-2008, 06:14 PM   #4
Default
Thanks for all the help! I Believe i followed everything in the directions you provided(from the link, and the 2nd post.) it still seems to be timed wrong, my front cylinder is actually blowing back out through the intake. Is there a chance i might have something reversed? Thanks again for all the help, Adam
Old 10-20-2008, 06:18 PM   #5
Feedback Score: 6 reviews
kujo's Avatar
View kujo's Photo Gallery(0)
Default
[/b]
did you turn the crank CLOCKWISE after setting the rear cam first? very important.. also did you set your valve lash?
SJXR1000
kujo is offline   Reply With Quote
Old 10-20-2008, 06:30 PM   #6
Default
Also, did you make sure to install the REAR cams in the rear head?
2007 KFX 730
Happy trails...
Old 10-21-2008, 01:05 AM   #7
Feedback Score: 9 reviews
hndlbarmonkey's Avatar
View hndlbarmonkey's Photo Gallery(0)
Default
Make sure you have the correct cam in the rear head, like they said. The rear cam has a small groove in the ring thingy, the front doesn't, just compare the two.
The easiest way is to set the flywheel on the TR mark and install the rear cam with the arrow on the cam sprocket facing up and the two small hash marks that are on the sprocket also, parallel to the head. Make sure the cam tensioners are removed. After the rear is installed, turn the crank with a 19mm wrench clockwise to the TF mark, which is 270*, then install the front cam just like the rear.
It sounds like you have the cams reversed, I done it and it did just what you described, would fire but not run and blow through the carb
If these are new cams and you've had everything cleaned good, use some engine/cam lube while assembling it
Home of the proven fastest and quickest all motor Kawies in the world
Quote: Originally Posted by Dynoray View Post
It says race because it was 12.6:1, instead of 11:1
lol, so going from 11:1 to 12.6:1 is building a race motor to you
LOL, back in 04-05, pretty much, LOL
AMR 840 trail bike
Fundy 800 race motored trail bike<wifes
Fundy 800 drag bike
It's nice when you get to a point, where you don't give a shit anymore
hndlbarmonkey is offline   Reply With Quote
Old 10-21-2008, 02:37 AM   #8
Default
[/b]
Valve lash?
Old 10-21-2008, 08:57 PM   #9
Default
you looking for the valve lash specs? stock or aftermarket cams? Stock I don't even remember, aftermarket cams, depends on who's cam you're running
AMR 840 trail bike
Fundy 800 drag bike
Old 10-22-2008, 05:14 PM   #10
Default
They are stock cams. The Cam with the groove is on the rear cylinder. Also, for some reason i have barely any compression now, and when i started it was fine. Is there some sort of compression release i sould know about? Never heard of one, and dont see were one could be. This thing is really throwing me for a loop. Thanks for all the help so far guys! Thanks in advance, Adam
brute force 650 cam timing
how to set cam timing on 03 prairie 650
how to set timing on prairie 650 v2
how to time a 03 650 prairie?
how to time a 2003 650 prarie
how to time a 2003 kawasaki prairie 650 atv
how to time a kawasaki 650vtwin
kawasaki 650prairey timeing
kawasaki prairie 650 timing
prairie 650 cam timing
timing a 650 prearie
timing a 650 prearie 2003 model
you tub timing a perary 650 atv
You may not post new threads
You may not post replies
timing and nos hndlbarmonkey Kawasaki KFX700 V-Force 21 02-17-2009 05:54 PM
Timing Key bean Kawasaki Brute Force/Prairie/Bayou 5 11-17-2007 06:31 AM
cam timing??? toolman Kawasaki KFX700 V-Force 5 08-18-2007 12:51 PM
Timing with NOS bb 650 Kawasaki Brute Force/Prairie/Bayou 8 03-29-2007 09:29 PM
NOS-Timing bb 650 Kawasaki KFX700 V-Force 14 03-18-2007 07:43 AM
