Fuel injection light on after Dielectric greasing everything.. HELP
This is a discussion on Fuel injection light on after Dielectric greasing everything.. HELP within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I spent the day installing MIMB snorks and dielectric greasing everything I could find on my bike. Well after installing the snorks I went to ...
Old 11-24-2008, 10:57 PM   #1
TEXAN AVIATOR's Avatar
View TEXAN AVIATOR's Photo Gallery(0)
Arrow
I spent the day installing MIMB snorks and dielectric greasing everything I could find on my bike. Well after installing the snorks I went to start the bike and it wouldn't start, and if it did it would die right away. I went back through most of the connections and one of the relays towards the back under the seat fixed the no start issue. Then when i started it the Fuel Injection light keeps flashing, and my PowerCommander doesn't follow the RPM revs by increasing on the light bar indicated on the PC. It just stays on the lowest bar no matter what RPM. Any suggestions?
2008 Team Green Brute 750I
31" Outlaws - 14" SS212s Black
2" Highlifter lift - Highlifter HD springs
EPI Red Secondary - Full Muzzy exhaust
Power Commander Dynotuned
Gorilla Axle - MIMB Snorkels
ASR X-Series tie rods - Pen-lock
Ammo Boxes - AudioPipe - Moose Backrest
Deep & Dirty ATV
Today America has chosen form over substance, emotion over logic, idealism over reality, but worst of all, color over quality. - Nov 4th 2008
TEXAN AVIATOR is offline   Reply With Quote
Old 11-25-2008, 06:55 AM   #2
Default
Anyone?
Deep & Dirty ATV
Old 11-25-2008, 12:57 PM   #3
Feedback Score: 1 reviews
View EHSRACING's Photo Gallery(0)
Default
Quote:
Anyone?
[/b]
probably one of the connections did snap together properly
EHSRACING is offline   Reply With Quote
Old 11-26-2008, 01:58 PM   #4
View speedy81304_KVF700's Photo Gallery(0)
Default
to much grease and its hard to get the water proof connectors to snap in all the way.
recheck everything and unhook your battery when doing so. so you dont short out the ECU.
also you might need to lean out the machine with the snorkles, since your slowing the flow of air into the enigne now.
I havent checked into it yet but on EFI machines you can jump to wires and it gives you a code why the FI light is flashing, to can track down your problem that way also but first find out witch wires to jump.
and get a list of the code numbers,
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline   Reply With Quote
Old 11-26-2008, 02:35 PM   #5
Default
[/b]
yes get you a service manual you can get it to flash a certain way to diagnose which connection is messed up. It will only basically tell you if it is faulty or not usually when they are out of spec or just glitchy it wont throw a code so you need to hunt crap down which is a pain.
Old 11-26-2008, 05:32 PM   #6
Default
yup EFI is great when its working right, or you can go nuts trying to figure out whats wrong, and find out a pin was pushed out just alittle and was making you have a bad day. been there done that, and i coast me a day at the track, sportbikes got more shtuff going on, and it was a real pain to find it had to pull every thing apart till i found the pin pushed out of the socket, put it back in and bingo no more EFI light and the motor ran good again, but cost me a day of riding and putting down laps at the track. you should get a manual just so you can fix your own little problems when your warranty runs out.
Muzzy Full System,
08 750 brute force fuel injected light staying on
2008 brute force 750 will not start f1 light flashing
atv fuel light
atv water dielectrc
brute force fuel injection code
brute force fuel injection light is flashing
brute force fuel injection lite
flashing fuel light brute forc
fuel injector light stays on kawasaki brute force
hard to start fi light on brute force
kawasaki brute force fi light
kawasaki brute force fuel injection system
why is the fuel injection light blinking on my kawasaki teryx
You may not post new threads
You may not post replies
Fuel Injection for the V bigguy3044 Kawasaki KFX700 V-Force 11 10-07-2008 05:50 AM
fuel injection spudnik Kawasaki KFX700 V-Force 5 05-23-2008 06:37 PM
FUEL INJECTION dakota_rt71351 Kawasaki KFX700 V-Force 36 01-20-2007 07:21 PM
FUEL INJECTION morehorsepower Kawasaki KFX700 V-Force 39 03-18-2005 09:33 PM
Where the heck is fuel injection? dmoell Kawasaki KFX700 V-Force 3 11-08-2004 04:22 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
