Brute 650 problem
This is a discussion on Brute 650 problem within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I've got a '07 Brute 650 SRA. It has always ran great with no problems starting or idling. It has sat for 2-3 months, and ...
Old 01-11-2009, 08:15 PM   #1
Killer__Shee's Avatar
View Killer__Shee's Photo Gallery(0) Send a message via MSN to Killer__Shee
Default
I've got a '07 Brute 650 SRA. It has always ran great with no problems starting or idling. It has sat for 2-3 months, and when I got it out for a ride there is a bad stumble in the bottom and severe popping from the exhaust when I let off from WOT. The quad will idle with the choke on when cold, but dies when i shut off the choke. Once it is warmed up, it won't even idle with the choke on. Has anyone else had this problem? Aby suggestions on where to start. I plan on tearing into the carbs, but was wondering if the choke sticking was still a problem like it was with the older Prairies and V-Forces. If so, does anyone have instructions on how to fix the stuck choke problem? Thanks.
Keep The Rubber Side Down !!!
2008 Honda 700XX
2007 Honda Rancher 420ES
Killer__Shee is offline   Reply With Quote
Old 01-11-2009, 08:31 PM   #2
View extreme750's Photo Gallery(2)
Default
I had the same problem with my BF750 and it turned out I had water in my fuel tank, so before taking your carbs apart like i did and end up with the same problem I would try to siphon out the old fuel first.
extreme750 is offline   Reply With Quote
Old 01-12-2009, 06:08 PM   #3
Feedback Score: 18 reviews
05-BF-750's Avatar
View 05-BF-750's Photo Gallery(4) Send a message via AIM to 05-BF-750
Default
Clean your carbs. You can't leave gas in your carb bowls if your going to let it sit for months at a time. Gas turns into gel. You will need to clean all your jets with a small wire. Very easy about 2 or 3 hours of work.
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-BF-750 is offline   Reply With Quote
Old 01-16-2009, 10:50 AM   #4
View Sapper33's Photo Gallery(0)
Default
I ran into an odd problem last time I ran my '08 BF 650i
Went for a rip at about -25C(-20F), while it didn't want to start, it got going (nothing likes to start that cold, especially carbs). It warmed up just fine, and seemed to be running fine, but I was at WOT for a good stretch (once warmed up), I let off the throttle rather than braking to slow down, but once the quad actually stopped, it stumbled and died. Had to be 60yrds of slowing down. I got it started again, but it was more difficult than I was expecting considering how warm the engine was.
Same thing happened again, was running close to WOT for a bit, then slowed down and "puttered" into the yard, got off the bike and went inside, and when I can outside a few min later, it had died again.
I'd really like to get this issue sorted out as I want to use this as a work quad next winter, but if it's not going to run well in the winter I'll have to settle for a set of Hondas...(shudder)
Sapper33 is offline   Reply With Quote
brute force 650 running problems
You may not post new threads
You may not post replies
Brute 750 choke problem? TODD4OO Kawasaki Brute Force/Prairie/Bayou 0 02-06-2007 04:36 PM
brute carb/rpm problem vtprairie03 Kawasaki Brute Force/Prairie/Bayou 3 10-14-2006 08:55 AM
Brute Problem, Please Help????? PSDboy Kawasaki Brute Force/Prairie/Bayou 4 08-16-2005 08:51 PM
brute 750 exhaust problem? Whitey Kawasaki Brute Force/Prairie/Bayou 4 08-16-2005 05:27 AM
flooding problem in brute deadpresidents Kawasaki Brute Force/Prairie/Bayou 4 03-10-2005 11:11 PM
