brakes longevity
This is a discussion on brakes longevity within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; i bought an '02 650 prairie last fall. it has 2000 miles on it. i went to adjust the rear brakes and they're all ready ...
Old 02-11-2009, 04:57 PM   #1
Feedback Score: 2 reviews
w_pinkerton's Avatar
View w_pinkerton's Photo Gallery(0)
Default
i bought an '02 650 prairie last fall. it has 2000 miles on it. i went to adjust the rear brakes and they're all ready turned in all the way i've heard of people getting 6000 miles out of them with some abuse. i just dont understand how they only lasted this long... this thing must have been beat to s#%t! is there anything else i should check when i have it apart? any other reasons on why they would have worn out this fast? how many miles have you guys been able to get out of your brakes? thanks!
2002 P650 - Dynatek CDI, '03 Airbox, UNI filter, Shimmed needles, 25" Kenda Executioners, Pink Primary, BF750 Secondary, KEBC Removed, Plug boot mod, ODI grips, Aluminum Products Skids, Maier Handguards, Elka Spring Kit, Dalton OD Cover
w_pinkerton is offline   Reply With Quote
Old 02-11-2009, 06:10 PM   #2
rms4545's Avatar
View rms4545's Photo Gallery(0)
Default
[/b]
Check and make sure that all the rubber plugs are in the swing arm. Look for any way that water or mud may have gotten in the swing arm. If it was run for a long time with contaminated fluid it would cause excessive wear.
I have over 4000 RACE miles on mine with original rear brakes.
Good luck
- Ryan
rms4545 is offline   Reply With Quote
Old 02-12-2009, 04:10 AM   #3
Feedback Score: 3 reviews
vtprairie03's Avatar
View vtprairie03's Photo Gallery(0)
Default
no problems here on any of mine... i had over 3k on mine... only issue i had was the rear brake cables.... (sucked)...
FST 730
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
vtprairie03 is offline   Reply With Quote
Old 02-12-2009, 01:21 PM   #4
rms4545's Avatar
Default
[/b]
Yes, i have gone through several brake cables for the rear hand brake. The only Solution i have found is to keep that cable well lubed and never leave the parking brake on unless absolutely necessary.
Old 02-12-2009, 01:31 PM   #5
Feedback Score: 15 reviews
Camo's Avatar
View Camo's Photo Gallery(0)
Default
What do the rubber plugs have to do with it? There is a seal on the pinion.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim
Camo is offline   Reply With Quote
Old 02-12-2009, 02:59 PM   #6
Supporting Vendor
Feedback Score: 7 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
I have worked on a twinpeaks with over 10k on it
His brakes still worked Amazingly well.
the brakes are like a clutch on a shifter bike.
How you treat them is how long they will last
www.VForceJohn.com (570) 773-1721
VFORCEJOHN is offline   Reply With Quote
Old 02-12-2009, 05:33 PM   #7
View NovaKaw650's Photo Gallery(0)
Default
[/b]
Ditto.
2002 665 FPS Prairie
FPS Trail kit - 12:1 comp due to 1mm shaved off the heads
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton springs and weights
Other stuff
NovaKaw650 is offline   Reply With Quote
Old 02-13-2009, 03:07 PM   #8
rms4545's Avatar
Default
Quote:
<div class='quotemain'>
[/b]
Ditto.
[/b][/quote]
well my seal on the pinion must be shot cause i was missing a rubber plug and ended up with water in my rear end fluid. I dont ever ride in deep mud or anything like that and i couldnt see any other way that the water could have gotten in there. Replaced that rubber plug and have not gotten any water in there since.
Old 02-13-2009, 04:16 PM   #9
Default
[/b]
Ditto.
[/b][/quote]
[/b][/quote]
I suppose if the water did lay in there long enough it might work its way by the pinion seal.
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Other stuff
Old 02-14-2009, 06:34 AM   #10
rms4545's Avatar
Default
[/quote]
I do believe that is what may have happened. I honestly cant say how long the rubber plug was missing. I was going over my prairie one day and came across it, immediately checked my fluid and sure enough it was Very contaminated.
You may not post new threads
You may not post replies
Where's the brakes? Andycyprus Club Kawie 1 02-17-2009 07:33 PM
brakes jamie Kawasaki KFX700 V-Force 8 09-17-2008 05:25 PM
brakes racerrick Kawasaki KFX700 V-Force 4 05-10-2008 07:18 PM
does the DYNATEK cause any longevity problems? ArcticMonster Kawasaki Brute Force/Prairie/Bayou 9 01-12-2007 12:24 PM
BRAKES!!!! SxysCowboy Kawasaki Brute Force/Prairie/Bayou 7 09-05-2004 09:25 PM
