FRONT DIFF P700 "05" COUPLING BEVEL
This is a discussion on FRONT DIFF P700 "05" COUPLING BEVEL within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; OK I got around to fixing my 2005 p700 I had a front diff leak coming from the back of the front diff where the ...
Old 02-26-2009, 05:03 PM   #1
PRAIRIEDOG700's Avatar
View PRAIRIEDOG700's Photo Gallery(0)
Default
OK I got around to fixing my 2005 p700 I had a front diff leak coming from the back of the front diff where the propeller shaft inserts into diff ok BIG SEAL around the coupling bevel and small one in the coupling bevel. Well I've been doing some reading and most people say if it leaks real bad it's probably because of the small seal so I took the nut lock 10mm off and checked it out ...... turns out I THINK it's the coupling bevel because it's got wear in to it where the big seal meets the surface... question is can it be cleaned up some with emery cloth or something more aggressive or will that take down the size of the couling bevel to much I think they go for $ 60.00 let me know and if your seal is leaking GET IT FIXED SOONER THAN LATER ! not like me.... her are some pic's of the scuffed up coulping bevel kind of hard to see but you get the Idea Thanks for any and all imput Anthony
http://i293.photobucket.com/albums/mm67/pr...PLINGBEVEL3.jpg
http://i293.photobucket.com/albums/mm67/pr...PLINGBEVEL2.jpg
http://i293.photobucket.com/albums/mm67/pr...PLINGBEVEL1.jpg
PRAIRIEDOG700 is offline   Reply With Quote
Old 02-26-2009, 05:13 PM   #2
Feedback Score: 7 reviews
asnowmobiler's Avatar
Location: Western Poconos (SOON)If they ever finish my new home..
Default
It's tough to tell from pictures,but it looks like it should be replaced. Mine has marks in it also,but they don't look that bad. I just installed a new seal,it won't be long till I see if it ok or not.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,VFJ X-over intakes, Looney Tuned Exhaust, programmable Dyna,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
Old 02-28-2009, 11:48 AM   #3
RKelly's Avatar
View RKelly's Photo Gallery(0)
Default
I would just shim the seal out a little and let it run in a new place.
05 BRUTE FORCE 750
04 V Force
87 230 quadsport kids
Alcohol Tobacco and Firearms
Who is bringing the chips?
Sounds like a party to me.
RKelly is offline   Reply With Quote
Old 02-28-2009, 12:20 PM   #4
Default
I'm not sure if that would be a good idea. It has teeth on it that would not be fully engaged if it's out farther.
AMR 330 347 6800
Old 02-28-2009, 01:19 PM   #5
RKelly's Avatar
Default
A shim under the seal. It will put the lips in a new location.
05 BRUTE FORCE 750
04 V Force
Old 02-28-2009, 01:25 PM   #6
Default
That just might work
AMR 330 347 6800
Old 02-28-2009, 01:34 PM   #7
RKelly's Avatar
Default
I do it all the time. It works good if you have a good suffice for the seal to run on.
05 BRUTE FORCE 750
04 V Force
Old 02-28-2009, 07:03 PM   #8
View speedy81304_KVF700's Photo Gallery(0)
Default
its kinda cool how rubber can wear out metal.
not saying that its cool your part is worn in.
but you would think that the seal would wear to nothing and the metal would just have a polished shin on it.
but then you got the dirt and grit that gets in there and works like a grinding wheel.
you can do what im going to do. is have the part cleaned then dipped in chrome. to make it nice and hard.
i wanted to find out if i could get a nikasil coating on it like whats found in sport bike cylinders. very hard thin coating last 4x longer then an iron cylinder.
this coating would not wear the seal would wear faster.
something to think about.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline   Reply With Quote
Old 02-28-2009, 08:05 PM   #9
Feedback Score: 2 reviews
View NovaKaw650's Photo Gallery(0)
Default
I would just replace the inner and outer seals; I bet your leak will be gone regardless of the grooving in the metal.
2002 665 FPS Prairie
FPS Trail kit - 12:1 comp due to 1mm shaved off the heads
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton springs and weights
Other stuff
NovaKaw650 is online now   Reply With Quote
Old 03-01-2009, 10:20 AM   #10
Default
Yea thanks guys for the imput I'm gona just but a new BEVEL $ 65.00 pluse tax ( ordered on FRIDAY they will have it WED ) but what SUCKS is we are about to get the MOTHER OF SNOW STORMS TONGHT 8-14 inches AND THE MACHINE IS DOWN I guess i will be shoveling or might RIG something up with the plow and a POLARIS 330 I have here either way My daughter and I will be riding later in the snow having a kick ass time ANTHONY
You may not post new threads
You may not post replies
"05" P700 overheating/FAN FUSE BUS many PROBLEMS PRAIRIEDOG700 Kawasaki Brute Force/Prairie/Bayou 8 08-04-2008 06:31 PM
P700"05" CLICKING IN FRONT DIFF IN REVERSE 4 WHEEL DRIVE PRAIRIEDOG700 Kawasaki Brute Force/Prairie/Bayou 2 06-05-2008 07:18 PM
New "old" front diffy fix... Mike Walker Kawasaki Brute Force/Prairie/Bayou 3 03-22-2007 09:42 AM
"4WD&2WD ind " "Belt reset plug""Front Shock Play" EuroBrute Kawasaki Brute Force/Prairie/Bayou 6 05-18-2005 07:29 PM
Please post pics of your P700 with 27" & 28" tires REPO Kawasaki Brute Force/Prairie/Bayou 6 04-19-2004 01:57 PM
