Starter Ring Gear
This is a discussion on Starter Ring Gear within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I had to replace my starter ring gear due to several broken teeth, I believe it has happened again. Is there any way around this ...
Old 03-29-2009, 03:25 PM   #1
rsnyder1976's Avatar
View rsnyder1976's Photo Gallery(0)
Default
I had to replace my starter ring gear due to several broken teeth, I believe it has happened again. Is there any way around this or do you just have to be careful when starting the quad and not let it kick back? Does this happen with the Diamond G DG5 and 6 degree key?
06 BF 665
14 INCH ITP TYPE C
27 INCH ITP XTR
HMF FULL EXHAUST
DYNOTEK CDI
K&N FILTER
2 INCH WHEEL SPACER
TUNNING BY BKP
rsnyder1976 is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 03-29-2009, 04:25 PM   #2
Feedback Score: 3 reviews
asnowmobiler's Avatar
Default
Mine kicks back sometimes.
The best way to avoid it,is to open the throttle a little when you crank it over.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,Dirty South +5 swingarm,39mm carbs, Looney Tuned Exhaust, programmable Dyna,front Elkas,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
Old 03-29-2009, 04:50 PM   #3
Feedback Score: 1 reviews
mikee's Avatar
View mikee's Photo Gallery(0)
Default
I have a starter gear if you need one.
08 Brute Force 750 EFI
Parting it out.
mikee is online now   Reply With Quote
Bookmarks
You may not post new threads
You may not post replies
stripped starter gear? brute650i Kawasaki Brute Force/Prairie/Bayou 55 07-31-2009 06:00 PM
starter/starter gear question Wild650 Kawasaki Brute Force/Prairie/Bayou 1 04-24-2009 05:33 PM
KFX700 Toasted Ring Gear TysonKFX Kawasaki KFX700 V-Force 8 12-30-2008 10:42 PM
noisy starter gear 67turbocamaro Kawasaki KFX700 V-Force 1 10-11-2007 09:30 AM
starter gear GnFnRs Wanted 2 07-21-2007 05:37 PM
