valve adjustment help - Kawasaki ATV Forum
post #1 of 9 Old 04-14-2009, 06:33 AM Thread Starter
I have a bruteforce 650 and am going to adjust my valves for the first time and could use some help from you guys besides removing the plastic is there any other crazy thing i should know should the valves be adjusted at the end of the specs or the beginning are there any pics of this anywhere you guys have been very helpful in the past i could really use the help today as i am a little nervous about even attempting this thank you in advance
dunny is offline
post #2 of 9 Old 04-14-2009, 06:50 AM
Supporting Vendor
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
set the cylinder you are working on TDC and adjust.
biggest mistake is people using the wrong flywheel timing mark. it's the line about 5mm to the left from the F and R marks. not the line that's on the letter.
its fairly easy once you have done it a few times.
.004-intake .006 exhaust.
it's a pain to get the feeler in there so loosen the nuts and screws first.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #3 of 9 Old 04-14-2009, 06:58 AM
Feedback Score: 1 reviews
700ccMARSHMELLOW's Avatar
I usualy turn it till the exhaust opens, and then barely starts to close and adjust the intake. And do the reverse for the exhaust. I do this cause sometimes the timing plug is a bitch to get off, or it is stripped out. I have never had negative issues arise from doing it this way.
700ccMARSHMELLOW is offline
post #4 of 9 Old 04-14-2009, 04:41 PM
wheelie_king's Avatar
I dont know about the 650 but on my 750 it is much easier to do the rear if you remove the battery and box.
wheelie_king is offline
post #5 of 9 Old 04-14-2009, 05:20 PM
Supporting Vendor
VFORCEJOHN's Avatar
Quote:
I usualy turn it till the exhaust opens, and then barely starts to close and adjust the intake. And do the reverse for the exhaust. I do this cause sometimes the timing plug is a bitch to get off, or it is stripped out. I have never had negative issues arise from doing it this way. [/b]
I do it the same way. I just crank it until the valve is fully closed. but telling someone how to do it the easy way. forget about it.
PHONE: 570-773-1240
post #6 of 9 Old 04-14-2009, 07:03 PM
Pkspawn's Avatar
I remove the inspection cover. Then the valve covers.
I get a socket on the bolt behind the stator cover.
I spin it counter clockwise. I almost see the F or R, and the fooker then just spins right past it. So I slowly do it again, trying to get it to stop at F or R and it just spins right on by..
So I just watched the valves and adjusted then after they closed like the others suggested.
Here is a website that had pictures. Its on a V, but pretty much same motor as you got. http://www.700v.com/valves.htm
Home of the World's Slowest and now Ugliest V-Force - Unofficial DragstripTime 4.2 - I was in front of 700mud filming him when he ran 4.4
PK, Inc - Stealing others Ideas since 1999!!</span>
Building the Ultimate Trail Machine: FST 715 BBK, Stage 2.5 cams, Twinair power Flo with 15 holes in airbox. Herrmann Racing A-arms and Anti-Vibe Steering Stem, Fluidyne Radiator, Hiper Wheels with Maxxis Razr2 tires. Fasst Flex Bars, Cycra Pro-Bend Handguards, Hardkor Front Hubs. Honda rear Hubs. AC Racing Wide Grab Bar, IMS Pegs, Heel Guard and Nerfs, Gas Tank. FST CDI, Elka Elite Front & Rear Shocks, 3/4 PRM Skids, THANK YOU FST - Maier Black Plastics , Muzy out - Muzzy Pro in.
On the way: Ultimate Trail and Race Carb Setup
Wishlist: Precision Stabilizer
<span style="color:#000000">Keeping it stupid:
25HP shot of NOS
&#39;08 KFX 700 - The one above looks like a pretzel.
Pkspawn is offline
post #7 of 9 Old 09-02-2009, 09:14 AM
very helpful link!
Here is a website that had pictures. Its on a V, but pretty much same motor as you got. How to: Adjust Valves
Am I correct in assuming thr front valves r the intake and the rear 1's r exhaust?
hutchy is offline
post #8 of 9 Old 09-02-2009, 10:23 AM
The intakes are the ones towards the throttle bodies or carbs. Exhaust is the outside ones where the exhaust head pipes come out.
09 Brute Force 750i
Evanrude is offline
post #9 of 9 Old 09-23-2010, 05:50 PM
Thanks for posting this...Kawi would not start properly..after reading a few threads here..we got her running great...also helped talking to the guy at the local dealership..she is road ready now..
lexiesmom is offline
05 kawasaki brute 650 valve adjustment
2006 kawasaki brute force 650 valve adjustment
adjust valves kfx 700
brute force 650 timing marks
brute force 650 valve clearance
brute force 750 valve adjustment
brute force 750 valve adjustment specs
brute force 750 valve clearance
easyest way to set valves 650 brute force
how to adjust valves on kfx 700
kfx 700 valve adjustment
valve adjustment kfx 700
valve specs kfx 700
valve adjustment vforce07 Kawasaki KFX700 V-Force 6 03-17-2008 04:11 PM
valve adjustment mike650 Kawasaki Brute Force/Prairie/Bayou 5 03-13-2008 04:42 PM
Valve Adjustment KevinM Kawasaki KFX700 V-Force 17 07-07-2005 11:08 AM
Valve Adjustment uinthas Kawasaki Brute Force/Prairie/Bayou 2 06-15-2005 12:19 PM
Valve Adjustment KevinM Kawasaki KFX700 V-Force 0 12-31-1969 07:00 PM
