starter/starter gear question
This is a discussion on starter/starter gear question within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Just got done doing the brute flywheel swap on my prairie. When I went to hit the ignition, the starter just whined without turning over ...
Old 04-24-2009, 05:19 PM   #1
Wild650's Avatar
View Wild650's Photo Gallery(0)
Default
Just got done doing the brute flywheel swap on my prairie. When I went to hit the ignition, the starter just whined without turning over the motor. What do I need to look for when I take it back apart to find out what I messed up on.
FST 765 w/ stage 2 cams, AMR trail porting, F4 36mm carbs, ProCircuit full pipe, dyna CDI, GTYR filter set up, stage 3 clutch w/ spider mod, flexx bars, shindy tach,
Wild650 is offline   Reply With Quote
Old 04-24-2009, 05:33 PM   #2
Feedback Score: 7 reviews
asnowmobiler's Avatar
Location: Western Poconos (SOON)If they ever finish my new home..
Default
Sounds like the gears aren't lining up for some reason,you should be able to see the problem easily once it's apart.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,VFJ X-over intakes, Looney Tuned Exhaust, programmable Dyna,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
You may not post new threads
You may not post replies
stripped starter gear? brute650i Kawasaki Brute Force/Prairie/Bayou 63 04-08-2010 05:12 PM
Starter Ring Gear rsnyder1976 Kawasaki Brute Force/Prairie/Bayou 2 03-29-2009 04:50 PM
noisy starter gear 67turbocamaro Kawasaki KFX700 V-Force 1 10-11-2007 09:30 AM
starter gear GnFnRs Wanted 2 07-21-2007 05:37 PM
no not again-starter gear limiter teeth shearing bosshog Kawasaki KFX700 V-Force 36 03-28-2007 09:28 AM
