2WD/4WD Indicator flashing
This is a discussion on 2WD/4WD Indicator flashing within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I have been doing some MODS on my '02 650 Prairie, including adding a toggle to the cooling fan. At one point, I caused the ...
Old 05-08-2009, 04:19 PM   #1
View tomhusker's Photo Gallery(0)
Default
I have been doing some MODS on my '02 650 Prairie, including adding a toggle to the cooling fan. At one point, I caused the 30A main fuse to blow on accident. Now, the KEBC actuator does not power on when I turn on the key, the 2WD/4WD indicator light is flashing back & forth and I can not get it to switch between 2 & 4 WD. The machine will start and seems to run fine. I haven't ridden it, due to not having the plastic on it yet from the paint job I am doing.
I really need some assistance with this one. I am lost with electrical issues. I practically need someone to point to where I need to look....
tomhusker is offline   Reply With Quote
Old 05-08-2009, 05:00 PM   #2
View kaw7000's Photo Gallery(0)
Default
[/b]
MY P700 HAS BEEN FLASHING BACK AND FORTH FOR YEARS HOPE SOMEONE CAN HELP US OUT ON THIS MATTER??
kaw7000 is offline   Reply With Quote
Old 05-08-2009, 07:19 PM   #3
Feedback Score: 18 reviews
05-BF-750's Avatar
View 05-BF-750's Photo Gallery(4) Send a message via AIM to 05-BF-750
Default
It can mean a few different issues. Either the engine brake actuator,
4wd actuator, speed sensor, or electronic control unit. All of this is in the kawasaki shop manual.
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-BF-750 is offline   Reply With Quote
Old 05-09-2009, 03:23 AM   #4
Feedback Score: 3 reviews
vtprairie03's Avatar
View vtprairie03's Photo Gallery(0)
Default
you can pinpoint it... the manual tells you to watch the time intervals between flashes... depending on how fast it is flashing will tell you whether its the 4wd actuator-kebc- or both.... i dont have the book infront of me right now or i would scan it for you and post it but im at work... you can also do a search and there is alot of info on the problem on here... its been discussed a bunch...
FST 730
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
vtprairie03 is offline   Reply With Quote
Old 05-09-2009, 01:49 PM   #5
Supporting Vendor
Feedback Score: 7 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
Sounds like a shorted ECU. the square box by the CDI
05-bf-750 is correct it can be any of the above
if you got no speedo sensor, it will do that as well, but not flash 4x4
kebc, you'll have no engine break or buzzing when you turn on and off the key
4x4 actuator, you'll have no 4x4
ECU nothing will work, but you'll have speedo
www.VForceJohn.com (570) 773-1721
VFORCEJOHN is offline   Reply With Quote
Old 05-09-2009, 05:08 PM   #6
Default
[/b]
I'll dig out my VOM and get to testing the ECU tomorrow. I have one around here somewhere.... I hope. Haven't seen it since I moved here a year ago. :P
Thanks for the replies. My search results were frustrating me.
Old 05-09-2009, 05:42 PM   #7
05-BF-750's Avatar
Default
Quote:
if you got no speedo sensor, it will do that as well, but not flash 4x4[/b]
John, I just had a speedo go bad on my 750 and the 4wd 2wd was falshing back in forth. What do you mean but it wont flash 4x4??
2005 kawasaki prairie 700 4x4 acuater
how to turn flashing 4wd and 2wd light off 08 brute force 750
why does my 2004 kawasaki atv flash 2 WD 4 WD
brute force 750 2wd blinking
kawasaki 2wd 4wd
brute force 650 fan fuse
brute force 2WD 4WD flashes back and forth
kawasaki atv 4wd switch problems
Computer indicators 2WD and 4WD lights on
04 kawasaki prairie 700 flashing 2wd to 4wd
why does the 4wd light flash on and off on my kawasaki brute force
2003 650 prairie 4x4 tec book
2004 kawasaki prairie 700 4x4 acuater
bruteforce 750 2wd/4wd
google kawaski prarie 4wd light
kawasaki prairie 700 speed sensor
kawasaki brute force 2wd/4wd actuator location
650 prairie 4x4 flashing
brute force wont go in 4wd
kawasaki prairie 700 flashing 2wd 4wd
You may not post new threads
You may not post replies
2wd/4wd flashing js198027 Kawasaki Brute Force/Prairie/Bayou 2 06-01-2008 04:47 PM
flashing between 2x and 4x4 harley1212 Kawasaki Brute Force/Prairie/Bayou 3 08-30-2007 01:06 AM
2wd 4wd light flashing TDART67 Kawasaki Brute Force/Prairie/Bayou 2 09-26-2006 06:19 PM
Strange happenings from belt indicator light Trail Time Kawasaki Brute Force/Prairie/Bayou 4 04-12-2004 04:21 PM
Flashing 2WD/4WD toadmax Kawasaki Brute Force/Prairie/Bayou 21 11-21-2003 07:34 AM
