frame builders. - Kawasaki ATV Forum
post #1 of 7 Old 05-25-2009, 08:42 PM Thread Starter
looking to builda new frame out of a stronger lighter DOM tubing, or something better.
with all the facotyr specs. and added gussets to make the frame stronger and better.
I'm thinking a bent my frame this past weekend. but dont know how.
my toe settings are in spec. but I can turn hard left and everything clears just fine, but hard right and my tire hits the floor board. theres 3/8" off but i cant seem to find how or where.
for me it dont really matter if the machine is lighter or not. but has to be stronger.
i know the fatory upper strut mounts are weak. and bend if you dont have a rack of strut brace.
so i would want a thicker stronger metal used also beef up the a-arm mounting points.
has anyone had a custom frame build or knows were to have one made.
my goal is to make my prairie last longer and hold up like a tank.
since its used for snow plowing, trail riding, mudding, sled pulling, and of course jumping, wheelies, and plain old, HOLD MY BEER IM GOING TO TRY SOMETHING kind of riding. lol
the factory frame held up pretty good i think. i never broke the cross tube under the seat like others have done. but I have rolled it once last winter. but the frame was not bent. every thing else was.
I dont know if its from when i was cruising down this one trail following my buddy on his TRX450R. and jumped off a hill. but my machine landed hard on the right front wheel. i dont know if i bent the a-arm or the frame for sure. but something is out of spec. it ride strait and handle normal. but like i said my right front tire now hits the floor board at full hard lock.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline
post #2 of 7 Old 05-26-2009, 09:23 PM
Feedback Score: 23 reviews
T_Dilley's Avatar
Shotgun made himself an aluminum frame, maybe he can give you some tips..
I don't think it went so good though..
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline
post #3 of 7 Old 05-27-2009, 03:26 AM
It would prolly be easier to get an old frame and add supports and bracing where you want if your planning to swap everything anyway.
Never under estimate a man that over estimates himself.(FDR)
The trouble with trouble is that it starts out as fun.(unknown)
Kawi '05 750 BF
EPI clutch springs maroon primary red secondary
LRD TORC pipe
moose cdi 6* key K&N air filter
2"S/S lift,2"spacers& Gorillas on the rear
29.5"Outlaws,12"HiLifters
MIMB snorkel&Temp gauage(HowTo)
drtyTshrt is offline
post #4 of 7 Old 05-27-2009, 04:36 AM
Feedback Score: 5 reviews
vtprairie03's Avatar
we have a local body shop guy that has bent back a few prairie frames for us... and a brute frame(my dads )... and he's good too.... it took some time getting the specs from kawie on the frames but he can put it back like new and even welds up stronger gussets on them while he's at it...
if you decide to go that route, talk to a few racers that have raced the prairies in the past and ask them where to weld the gussets at or where the weak points are at.........
FST 730
LTE DUALS
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
2007 kfx 90
120cc powroll bbk
cam'd
two brothers full exhaust
ac racing nerfs
rath racing front and rear bumper
jb racing +2 a arms
previous motors..
fst 765-stage 3 cams-full porting-lte duals
amr 800-ported big valve heads-x3 cams- lte duals..
vtprairie03 is offline
post #5 of 7 Old 05-28-2009, 10:00 AM Thread Starter
thanks guys,
I wounder if mike pennland would tell me the strong and weak points of the prairie frame.
I know he used to race them.
anyone know some old prairie GNCC racers.
I can get a new frame from ronayers, has no vin or title, have to stamp old vin into new frame then cut off and send back the old frame vin to kawie, so they can file off as the frame has been replaced.
Ill order the new frame soon, and work on getting gusseting info, and beef it up before i swap everything over.
Muzzy Full System,
post #6 of 7 Old 05-28-2009, 08:48 PM
T_Dilley's Avatar
Get with member XCHAMP on here, I'm sure he will steer you in the right direction.
VFJ has a low hour Prarie frame also w/ wiring. Surely it will be cheaper than going through Kawisaki
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
T_Dilley is offline
post #7 of 7 Old 05-29-2009, 10:05 AM Thread Starter
I'll still go with a new kawie frame, so i dont need a new title.
know plans to get ahold of Xchamp.
I know VFJ has talked about the one rear cross member tube behind the battery breaking, so I would weld that up and gusset that area. IM sure the weak poiints are in the front of the machine. wear kawie didnt fully weld up the factory gussets ans water and dirt can gut up in there rust and weaken the frame over time.
will be checking into this deeper, need to make my Prairie last a life time. lol
Muzzy Full System,
2009 kawasaki teryx chassis build
atv chassis builders
atv chassis builders indiana
atv custom frame plan
atv frame builders
bent my atv frame , got a used one can i put my vin on it
can i use dom tubing for atv a arms
custom atv frame builders
custom riders atv frame
frame builders gussets
frame builders kawasaki
what kind of metal is a kfx 700 frame made of?
which atv as the strongest frame
builders cams sturmenater Wanted 0 04-18-2009 03:11 PM
Cams from builders The Speed Force Kawasaki KFX700 V-Force 5 03-18-2008 09:46 PM
engine builders dusty Kawasaki KFX700 V-Force 19 09-06-2007 07:53 AM
HEY ENGINE BUILDERS coolinthewoods123 Kawasaki KFX700 V-Force 9 04-04-2007 04:52 PM
Why we love the builders... MetalAlien Kawasaki KFX700 V-Force 20 11-13-2006 09:30 PM
