Old 05-27-2009, 08:38 AM   #1
View drtyTshrt's Photo Gallery(0)
Default
Just changed my plugs and the front one was smut black,no biggie I did not know how long it had been in there. The rear looked better but not pretty and clean ,you know what I mean. ANYHOW put in the new plugs and ran it around the yard less than 2 mins and checked the front again brand new and smut black. I did not do a full throttle chop so I do not really know if it loaded up on idle at shut off. I have no idea what jets or needle postions I have either. any pointers?
Never under estimate a man that over estimates himself.(FDR)
The trouble with trouble is that it starts out as fun.(unknown)
Kawi '05 750 BF
EPI clutch springs maroon primary red secondary
LRD TORC pipe
moose cdi 6* key K&N air filter
2"S/S lift,2"spacers& Gorillas on the rear
29.5"Outlaws,12"HiLifters
MIMB snorkel&Temp gauage(HowTo)
drtyTshrt is offline   Reply With Quote
Old 05-27-2009, 08:41 AM   #2
Feedback Score: 5 reviews
vtprairie03's Avatar
View vtprairie03's Photo Gallery(0)
Default
ive been told to do a high speed run and shut the bike off... get off and check your plugs then go from there...
FST 730
LTE DUALS
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
2007 kfx 90
120cc powroll bbk
cam'd
two brothers full exhaust
ac racing nerfs
rath racing front and rear bumper
jb racing +2 a arms
previous motors..
fst 765-stage 3 cams-full porting-lte duals
amr 800-ported big valve heads-x3 cams- lte duals..
vtprairie03 is offline   Reply With Quote
Old 05-27-2009, 09:48 AM   #3
greasemonkey's Avatar
View greasemonkey's Photo Gallery(0)
Default
[/b]
You should warm up the engine and then do a full throttle run.Shut off the ignition as you let off the throttle and stop right away or atleast put it in neutral so the engine doesn't spin with no spark.Now check the plugs.This will tell you how your main jetting is.Just driving around the yard you are using your slow speed jet and your idle mixture screw adjustment so you won't be able to tell your jetting.If the plugs are fine at full throttle and your plugs are black at low speed then it could be a few things.Either your slow speed jets are too big,your idle mixture screws are way out of adjustment ,or your choke plungers are stuck partially open.I have been reading about the choke plunger problem alot lately.
good luck
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline   Reply With Quote
Old 05-27-2009, 10:03 AM   #4
Default
I am leaning towards the choke plunger also just because of what I have been reading, and the guy I bought from was telling me about it being cold natured . I am begining to take all that he has told me with alot of skeptism lately. The wheel is a beast and I have not had any motor problems I am just doing the PM and going over it with a fine tooth comb. I knew about the full throttle chop to check the plugs I was just sitting here at work and thought I would post for more ideas. I will do this and check today hopefully.
Kawi '05 750 BF
LRD TORC pipe
06 brute force 750 spark plug gap
2002 kawasaki brute force 750 spark plug gap
2003 kawasaki bayou 250 spark plug very black
2007 brute force 750 spark plug black
2009 kawasaki brute force gapping spark plug
brute force 750 cold nature start up
spark plug gap for brute force 750
spark plug gap on 2008 750 efi brute force
spark plug gap on a 2009 kawasaki bayou 250
spark plugs for a 1994 kawasaki 700 prairie
what it is the gap plug for a kawasaki bayou 250 1995
You may not post new threads
You may not post replies
spark plug VENFORCER Kawasaki KFX700 V-Force 7 02-11-2008 08:11 AM
SPARK PLUG GAP 1nastyV Kawasaki KFX700 V-Force 3 07-13-2007 06:28 AM
spark plug boot mod.......plug gap? STOGI Kawasaki KFX700 V-Force 1 05-24-2007 07:40 PM
best spark plug to run? vbob Kawasaki KFX700 V-Force 14 10-14-2006 05:04 PM
Spark Plug Gap Mr J&J Kawasaki KFX700 V-Force 2 07-15-2005 08:22 AM
