Drive Belt Problems - Page 3 - Kawasaki ATV Forum
post #21 of 25 Old 11-06-2010, 07:36 AM
ALDO's Avatar
I dont't know if with the kw 700 is the same but in the 360 there are some spacers in the secondary, that will tight the belt, because the belt loosen a bit when in use, you have to check the deflection, try to see the service manual. I think there are the same thing.
ALDO is offline
post #22 of 25 Old 11-06-2010, 08:16 AM
I think the only problem I have is the belt light comming on, which started when I was practiceing wheelies.( I printed off what to do next time that happens ) I have heard Polaris is a belt eater and must go in low for slow speeds, but I now understand its easier on the bike to be in low at slower speeds, I will keep that in mind, thanks.
don-don is offline
post #23 of 25 Old 11-26-2010, 05:47 PM
Quote:
Originally Posted by don-don View Post
Regarding low under 25 mph, Im always in high, except if I tow, or i am putting a real load on the drive, deep mud, or plowing. Ive never really lacked for power, I just thought thats what its for. Now you have me wondering, should I be in low more often?
Yup, under 25 Mph is crap! I use both ours in High most of the time and only use low if I'm hauling or slow technical stuff, like bog, mud or climbing at slow speed.
Today for the 1st time I dived into the clutches as it was suttering on hard take off or strain but just for a second. I checked the deflection and it was 28mm. I have it on the tight side now as there was only 1 shim in the secondary (1mm) and with it out the deflection is now 19 which is tight but at least it's better for now until I get some shims next week. Need a 0.6mm shim to get it close to 22mm. It squeeks only in gear but doesn't move at idle so it's not bad. Better tight then too loose.
I have 900kms on the stock belt and it's down to 27mm wide at the top so the belts do last so the mileage the OP is getting means something is wrong and his dealer is filling him full of Crap!
WOLVERINE is offline
post #24 of 25 Old 11-26-2010, 06:14 PM
linehaul's Avatar
ok the reason i bought a brute is my buddy has a 05 650sra w\27"horns
i have never seen him use low on any hills he has beat the livin snot!!
outa this thing ,1800 miles belt light been on for 2 yeas and it still goes anywhere he points it . but what i wanna know is clay85 still having problems after 18mo or did he get fixed
linehaul is offline
post #25 of 25 Old 11-27-2010, 03:14 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
If I know a rough section is going to last more than a couple of minutes, then I will use low range.
The guys the run big tires and mud all the time can run high range if they want, but those of us that have been around for a while have seen what that can do to a clutch over time.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
4010 mulr drive belt adjustment
belt drive slipping on a 2007 3010 kawasaki mule
belt problem 750 brute
belt wrong direction on a 550 mule
drive belt for 610 mule
how 2 tighten belt on 4 weeler
how do you change drive belt on kawasaki mule
kawasaki 4010 mule drive belt
kawasaki brute force problems breaking belts
kawasaki mule 3010 clutch adjustment
mule 3010 heavy duty belt
when should i change the drive belt on my 4-wheeler?
why is my kawasaki 4010 diesel drive belt breaking
Teryx Drive Line Problems xchamp Kawasaki Teryx 9 03-18-2009 06:06 PM
P650 4wheel/2wheel drive problems branman444 Kawasaki Brute Force/Prairie/Bayou 5 11-13-2007 07:41 PM
P650 4wheel/2wheel drive problems branman444 Kawasaki Brute Force/Prairie/Bayou 1 11-08-2007 11:33 AM
drive belt 2BlueHeelers Kawasaki KFX700 V-Force 3 07-01-2007 01:28 AM
Need drive belt for 650 Sarge Kawasaki Brute Force/Prairie/Bayou 8 05-08-2005 06:19 AM
