2" Lift Kit P700
This is a discussion on 2" Lift Kit P700 within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; How does this kit effect the stability. I decide to go ahead and order one since I already have changed the strut springs, ball joints, ...
Old 07-02-2009, 05:30 PM   #1
View dmoyers's Photo Gallery(0)
Default 2" Lift Kit P700
How does this kit effect the stability. I decide to go ahead and order one since I already have changed the strut springs, ball joints, brake pads, tie rods, cv boots, etc. I realize that the drive angles will change and the center of gravity will change, but I also added a full set of Ricochet skids and a winch which will add some weight below center. Should I get a set of 1 1/2" wheel spacers? Is urethane the way to go?
dmoyers is offline   Reply With Quote
Old 07-03-2009, 01:17 AM   #2
Feedback Score: 15 reviews
Camo's Avatar
View Camo's Photo Gallery(0)
Default
I never noticed any difference on my P... but I don't run the stock wheels.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim
Camo is offline   Reply With Quote
Old 07-04-2009, 07:54 AM   #3
Default
My wheels are not stock either, but I believe the combo is of stock size (25"). Are you running spacers?
Old 07-05-2009, 04:00 PM   #4
greasemonkey's Avatar
View greasemonkey's Photo Gallery(0) Send a message via ICQ to greasemonkey
Default
I have the lift on my 650 . Side to side stability is ok.The only problem is going up steep hills .If you don't put your weight forward it will want to lift the front wheels and roll over backwards.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline   Reply With Quote
Old 07-07-2009, 09:26 AM   #5
View speedy81304_KVF700's Photo Gallery(0)
Default
the lift doesnt really give you more ground clearance on the rear axle. but more on the frame. its pretty stable. but can still tip over faster then a stock machine. if your going for larger tires. 28" fit nice, and with some aftermarket wheels with better offset like the ITP wheels. handling will be much better. add a set of 1" wheel spacers and it gets harder to tip over. my machine with 1.5" wheel spacers and rolling on delta steel wheels with 28x10-12 fronts and 28x12-12 rears. its just as stable as a stock machine but looks better. my machine is 5" wider then a stock machine helps with handling and helps with staying out of deep ruts by riding on the edges of the ruts, but sucks fitting on tight trails that a stock machine can as being 5" wider i rub trees more with the tires.
2004 RED P700 Trail monster
Muzzy Full System,
speedy81304_KVF700 is offline   Reply With Quote
Old 02-15-2010, 06:38 PM   #6
dafoosa's Avatar
View dafoosa's Photo Gallery(0)
Default
I just added a 2" lift and some HL 1.5" wheels spacers to my P700.Its sitting on 28" Swamplites and feels very stable,more so than when it was stock on 26" Mud bugs
dafoosa is offline   Reply With Quote
You may not post new threads
You may not post replies
working on a new lift for my P700 speedy81304_KVF700 Kawasaki Brute Force/Prairie/Bayou 2 06-01-2009 12:34 PM
FRONT DIFF P700 "05" COUPLING BEVEL PRAIRIEDOG700 Kawasaki Brute Force/Prairie/Bayou 13 03-05-2009 07:56 PM
Jeep XJ 3.5-4.0" Lift on! KFXHELLRAISER Club Kawie 29 07-07-2008 06:42 AM
P700"05" CLICKING IN FRONT DIFF IN REVERSE 4 WHEEL DRIVE PRAIRIEDOG700 Kawasaki Brute Force/Prairie/Bayou 2 06-05-2008 07:18 PM
4 inch lift for P700 speedy81304_KVF700 Kawasaki Brute Force/Prairie/Bayou 4 07-25-2007 01:17 PM
