Water protection for 12 hole mod
This is a discussion on Water protection for 12 hole mod within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Anyone have any tricks for keeping water out of the airbox with the 12 hole mod? I tried taping the holes shut to run it ...
Old 07-02-2009, 09:47 PM   #1
View stumper's Photo Gallery(0)
Default Water protection for 12 hole mod
Anyone have any tricks for keeping water out of the airbox with the 12 hole mod? I tried taping the holes shut to run it in a mud race and it wouldnt run at WOT,just spit and sputter...
2007 650 SRA
Dynatec CDI
Dalton O/B spring
12 hole Mod
K&n filter
LRD pipe
And a few other KR tricks I picked up along the way
ITP type 7's
ITP holeshot ATR's for the grass
SWamp fox mudders
stumper is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 07-02-2009, 10:09 PM   #2
Feedback Score: 3 reviews
twyztid's Avatar
View twyztid's Photo Gallery(8)
Default
Maybe you could contact Outerwears to have them make you one of their water-resistant covers that would fit over your airbox cover with elastic or something. Then it is easily removable when you are done with the race since it will probably be pretty covered in dirt/mud. Then just rinse it off with water and let dry before you need to use it again. I have had their water-resistant covers on the air filters on other quads I have owned and they work pretty well at repelling water unless you give them a direct, hard spray from a hose or something.
'04 Green KFX730
Fundy 11.1:1 Pistons, FST Stage 2 cams, HMF Dual Exhaust, +4 Swingarm Extension, 12-Hole Mod, UPP Cross-over Intakes, 6* Timing Advance Key, #43 drilled main jets, #42 pilots, needles 1.2mm shimmed, Spark Plug Boot Mod, Elka Front Shocks, Revalved Rear Shock w/ Road Magnet Spring, TrailTech X-bars/Clamp, Pro-Armor nerfs--bumper--grab bar, 25x12-10 10-paddle Skat-Trak Extremes on 10x11 wheels, EPI Almond Spring w/ 2 shims... 5.655 in 300' sand drags with stock bolt-on motor (haven't raced the 730 yet)
'04 Orange KFX700
DMC Afterburner Quiet4 Dual Exhaust, 12-hole Airbox Mod, 180f/182r main jets, shimmed needles, 6* Timing Advance Key, Spark Plug Boot Mod, Road Magnet Suspension Springs,
24x11-10 8-paddle Skat-Trak Extremes on 10x10 wheels, EPI Pink Spring
twyztid is offline   Reply With Quote
Old 07-03-2009, 08:10 AM   #3
Feedback Score: 9 reviews
05-BF-750's Avatar
View 05-BF-750's Photo Gallery(4) Send a message via AIM to 05-BF-750
Default
On the SRA models the napa hose mod or DG snorkel make better power then the 12 hole will. The 12 hole is more for the KFX.
2005 FPS 700= FPS BBK, VFJ clutch, Quadboss full skids, K&N Filter,12 hole mod, 42 pj, LTE dual exhaust, Spark plug boot mod, ASR SS Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Madd Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-BF-750 is offline   Reply With Quote
Old 07-03-2009, 09:05 AM   #4
Default
I know that what is said, but for some reason thats not the case with my machine. Difference of about 2 quad lengths between the 12 hole and napa hose when racing the same machine.Actually I have 3 of the holes taped shut.....
2007 650 SRA
Dynatec CDI
Dalton O/B spring
12 hole Mod
K&n filter
LRD pipe
ITP type 7's
SWamp fox mudders
Old 07-03-2009, 10:28 AM   #5
Feedback Score: 1 reviews
View riverkid's Photo Gallery(0) Send a message via MSN to riverkid
Default
I had an old outerwears cover laying around so i just cut it fit over the holes and glued it to the cover. Just take the hole lid off to clean it and keeps alot of dust and water out of the holes. And you can still tape a few holes shut from the inside of the cover.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline   Reply With Quote
Bookmarks
You may not post new threads
You may not post replies
Silver protection Brutegirl Kawasaki Brute Force/Prairie/Bayou 6 03-29-2008 05:20 AM
BRUTE PROTECTION Brutegirl Kawasaki Brute Force/Prairie/Bayou 18 06-08-2007 02:42 PM
Back protection...What do you use? KTM265 Club Kawie 27 10-03-2006 09:52 PM
Protection for ur Wench ;-D Sarge Kawasaki Brute Force/Prairie/Bayou 10 08-17-2004 12:56 PM
Back protection...What do you use? KTM265 Kawasaki KFX700 V-Force 0 12-31-1969 06:00 PM
Content Relevant URLs by vBSEO 3.3.0
