Brute 650 VS 650I
This is a discussion on Brute 650 VS 650I within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Hi everyone I'm new to the forums and I must say there are some very knowledgeable people here. Now I'm in the market for a ...
Old 07-04-2009, 10:48 AM   #1
DaveFroti's Avatar
View DaveFroti's Photo Gallery(0)
Post Brute 650 VS 650I
Now I'm in the market for a new ATV and the Kawasaki V-twins are really tempting and the prices are just best bang for the buck. Now of course I've used the search button to find some answers, but after 11 pages I didn't find anything that would answer my questions.
1- What would be the best for 70% Trail rider, 20% Deep Woods, 10% Mud to the floor boards. What are the great advantages of Dual A-arms up front vs the MacPherson struts
2- I know that the SRA 650 has different jugs then the 650I which means that if any engine modifications is to be done I'm going to be looking at a 700crank for a BBK.
3- Are there 2 different version of the CDI for the 650s? I Can't seem to find the info on Dynatek.
4- Also what is the advantage of the 650i's dual 34 carbs VS the 650 dual 32carbs
Thanks
Dave F.
DaveFroti is offline   Reply With Quote
Old 07-14-2009, 03:18 PM   #2
DaveFroti's Avatar
Default
Wow, no answers.
Here's to hoping someone can shed some light?
Old 07-14-2009, 03:53 PM   #3
Feedback Score: 7 reviews
asnowmobiler's Avatar
Location: Western Poconos (SOON)If they ever finish my new home..
Default
The SRA is more like riding a over weight sport quad,the IRS will be smoother riding and better in the deep mud.
The heads are better on the "I" but you can still get awesome power out of the SRA 650 heads and shouldn't be a concern unless your going all out.
The CDI's are different.
The bigger throttle bodies will benefit you more the bigger you go and the better your engine flows.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,VFJ X-over intakes, Looney Tuned Exhaust, programmable Dyna,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
Old 07-14-2009, 04:19 PM   #4
Feedback Score: 3 reviews
kujo's Avatar
View kujo's Photo Gallery(0) Send a message via MSN to kujo
Default
the power difference between the I and sra is definaltely noticable, the I is a potent lil bastard stock.. i have a brute 750I and a prairie 650 and i actually find the brute handles better, the front is way better because i find the struts are way too soft on the prairie.. but keep in mind my 750 is a bit wider than stock, and has energy suspension sway bar bushings that really takes the sway out.. the I has better heads, bigger carbs, lighter flywheel, better cams, etc..
DS1000
VULCAN 1600 CLASSIC
ZX12R
KD80
kujo is offline   Reply With Quote
Old 07-14-2009, 04:28 PM   #5
View stumper's Photo Gallery(0)
Default
I guess I dont agree with the IRS being better in mud. Every IRS I have seen is sitting MUCH lower than my SRA after one ride through the thick stuff. They gather and hold so much extra weight from the mud that the IRS sags terribly. That dont happen with the SRA.They may start out with more clearence,but they sure dont end up that way.
2007 650 SRA
Dynatec CDI
750 flywheel/stator
Dalton O/B spring
12 hole Mod
X over intakes
carbs slides are polished
K&n filter
LRD pipe
And a few other KR tricks I picked up along the way
ITP type 7's
ITP holeshot ATR's for the grass
SWamp fox mudders
stumper is offline   Reply With Quote
Old 07-14-2009, 04:53 PM   #6
Default
Then you need stiffer springs.
It will take away some of the good ride that they came with,but there is always a trade off.
The SRA's can do very well with a good rider,but in most cases the IRS's clearance will take over in the deep sticky mud.
I'll take the SRA Kawasaki's over the IRS Kawasaki for what I like,but if I bought a CanAm it would be a different story.
AMR 330 347 6800
Old 07-14-2009, 05:24 PM   #7
DaveFroti's Avatar
Default
Wow, this is the type of responses I was looking for. keep'em comming.
thanks guys
Old 07-14-2009, 07:08 PM   #8
chestnutglade's Avatar
View chestnutglade's Photo Gallery(0)
Default
I like the SRA because less to work on and less to wear out .Looks simpler to work on.
650 B. F.almond primary,almond secondary,58wts's,moose mod,custom front and rear bumpers coated with rhino coating,custom skid plate,custom 4 snorkels ,2 inch HL lift kit,28 MST's tires,cycle country CV guards,HL springs,4000 lb viper max winch
chestnutglade is offline   Reply With Quote
Old 07-14-2009, 08:01 PM   #9
Feedback Score: 2 reviews
w_pinkerton's Avatar
View w_pinkerton's Photo Gallery(0)
Default
i agree.. fewer moving parts = fewer parts to replace.
i'm not in mud very much and when i am it usually isn't deeper than the floorboards, so the sra is fine with me.
but in a couple years i would like to upgrade to the 650i/750i... theres a ton of stuff you can do to them to get them to handle as good as the sra.
it all depends on how much $$ you want to spend
2002 P650 - Dynatek CDI, '03 Airbox, UNI filter, Shimmed needles, 25" Kenda Executioners, Pink Primary, BF750 Secondary, KEBC Removed, Plug boot mod, ODI grips, Aluminum Products Skids, Maier Handguards, Elka Spring Kit, Dalton OD Cover
w_pinkerton is offline   Reply With Quote
brute force cams power difference
winch plate needed for a 2006 brute force 650i
650 brute force no start with button no lights
difference between brute force 650 and 650i
what's the difference between 650 brute force and 650i
You may not post new threads
You may not post replies
Brute 650i 007BF Kawasaki Brute Force/Prairie/Bayou 0 01-31-2008 03:20 PM
Brute 650i 007BF Kawasaki Brute Force/Prairie/Bayou 0 01-17-2008 06:26 PM
Brute 650i 007BF Kawasaki Brute Force/Prairie/Bayou 21 12-05-2007 04:24 PM
brute 650i jasonbuck8 Kawasaki Brute Force/Prairie/Bayou 14 07-03-2007 05:37 AM
Can-am 650 or Brute 650i BruteForceCowboy Club Kawie 14 12-21-2006 08:17 AM
