MIMB snorkel engine intake question - Kawasaki ATV Forum
post #1 of 15 Old 07-05-2009, 08:04 PM Thread Starter
canadien4x4's Avatar
Well I'm about to do the snorkel mod tomorow. Only one question... does the engine intake snorkel make alot of noise? I don't mind some engine noise.... but I hate the sucking sound that the engine makes when you take the air filter cover off. Let me know so I can make my decision.
canadien4x4 is offline
post #2 of 15 Old 07-05-2009, 08:38 PM
hondarecoveryman's Avatar
Engine intake makes no noise when compared to the belt exhaust.... the CVT whine becomes MUCH louder than with stock
2003 P650 : Lifted,Snorkeled,Moose Module,26''589's(9's &12's),Super Grip Typhoon Wheels, MIMB clutch mod,Viper 4000lb.
hondarecoveryman is offline
post #3 of 15 Old 07-06-2009, 04:55 AM Thread Starter
is it an anoying noise for trail riding?
post #4 of 15 Old 07-06-2009, 06:29 AM
No. Once you get into it and on your way the belt noise goes away. I find myself putting it in neutral at a stop to minimize the belt whine. But moving along there is no real annoying noise once moving.
2007 BF750i
EPI Heavy Duty Clutch Kit
27" ITP 589 M/S
3.0 Warn RT Winch
ITP SS 108 Black
HL Radiator Relocation Kit
HL Temp Gauge
Rack Trunk Seat Box
2008 BF750i EFI
26" ITP 589 M/S
3.0 Warn RT Winch
Gun Racks
Monster Energy Decal Kit (To make it faster)
MIMB Snorkels
HL Temp Gauge
Wish List for 08:
HL Oil Cooler Kit
HMF Swamp Series Exhaust with Snorkel
Doebeck Gen III EFI Controller
VTBF750EFI is offline
post #5 of 15 Old 07-07-2009, 09:00 PM
At 30 mph mine is sceamin! You can hear the CVT clutches , The squeal at a idle you are hearing is normal at idle ,just means belt defection is good . If you want to stop that noise remove the KEBS crap
post #6 of 15 Old 07-09-2009, 05:22 AM
PDiablo's Avatar
I noticed more noise right away when I first installed the snorkels. Although I got used to it very quickly and it just seems normal now. The HMF exhaust is loud enough to distract my attention away from a little belt whine.
I also smell the belt from the CVT ext when I am pulling a heavy loads or putting around too slow in high range.
2008 BF750-
HMF, snorkeled, 27" IPT ML radials, a few home remedies
2003 Bayou 250-
k&n, jetted
PDiablo is offline
post #7 of 15 Old 07-09-2009, 04:18 PM
Muddy Brute Force's Avatar
Yes, you will hear the airbox intake sucking air more than what you do now, but after a little bit you will get use to it. What I like about being able to hear to sucking sound in the airbox snorkel, is that I can tell if my bike/carbs have any other problems that you normally wont hear.
2008 Kawasaki Brute force 650 SRA
Dynatek CDI
MIMB 2" Snorkels
Full Muzzy Exhaust, Jetted 145f 150r
K&N Air filter w/prefilter
V-Force John Stage 2 clutch mod, Stock Primary/Black secondary
Temp. Gauge, Radiator Relocate
Viper Max 3000lb winch w/ Synthetic Rope
ITP SS106 Wheels, w/ 28" Maxxis Zilla's
Bison Front & Rear Bumpers
Split Audio Tube
Garmin Etrex Vista HCX GPS
Catch Can Mod.
Intake Crossover Mod.
Muddy Brute Force is offline
post #8 of 15 Old 07-10-2009, 05:43 AM
greasemonkey's Avatar
Has anyone tried putting some cone style air filters on the end of the snorkles to quiet the noise down.This would also keep dust and dirt out and work as a prefilter for the engine intake.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline
post #9 of 15 Old 07-11-2009, 02:24 AM
You already have 1 air filter, by adding another filter, you will only be restricting the air flow, which will cause more jetting problems. If you are that concerned with dirt/sand getting into your motor, just add the prefilter to your exsiting filter.
Dynatek CDI
MIMB 2" Snorkels
Split Audio Tube
Catch Can Mod.
post #10 of 15 Old 07-11-2009, 03:56 AM Thread Starter
Quote:
What about one on the CTV intake.... if that really matters
2007 kawasaki bayou 250 snorkel
bayou 250 snorkel
ford raptor snorkel kit
mimb atv
mimb atv forums
mimb forum
mimb forums
mimb rad relocation
mimb snorkel
mimb snorkel kit
mimb snorkels
snorkel kit for bayou 250
Prairie intake snorkel - need help mn650 Kawasaki Brute Force/Prairie/Bayou 2 06-30-2008 03:34 PM
another snorkel question JD750 Kawasaki Brute Force/Prairie/Bayou 1 01-26-2007 03:46 AM
Intake Snorkel, P650 MuskwaMudder Kawasaki Brute Force/Prairie/Bayou 14 04-26-2005 05:48 PM
dg snorkel question kalel123 Kawasaki KFX700 V-Force 1 09-18-2004 10:33 PM
Air intake (snorkel) mod?? MIK6 Kawasaki Brute Force/Prairie/Bayou 4 08-18-2004 03:13 PM
