750 4x4i electrical malfunction - Kawasaki ATV Forum
post #1 of 13 Old 08-05-2009, 08:09 PM Thread Starter
This is a weird one fellas. Bike starts and runs fine with manual start but has no operation of the electronics. No cooling fan operation, no 4x4 activation, no electric start, no display. From time to time the display intermittently comes on at idle but when you rev the engine up the display shuts off. Oddly enough as soon as you attempt to turn the lights on the engine shuts off.
My first thought is a control unit problem. Ive inspected the connectors, all are seated properly, no corrosion and no bent pins. Fuses are all OK. Ive tapped on the ecu and the connectors and the display unit while it was working and this did not seam to effect anything.
Anybody else run into a similar problem???
Grutt is offline
post #2 of 13 Old 08-05-2009, 09:49 PM
What year is it? Assuming 08-09 since you mentioned the ECU.
A significant portion of that stuff is controlled by the actuator controller, not the ECU....
engie is offline
post #3 of 13 Old 08-06-2009, 09:30 PM Thread Starter
Not sure on the year, this is a buddys bike and he is out of town. He has had it a couple years tho. Maybe this is an actuator controler I am refering to as a ecu. There is one with a mitsubichi symbol on it and one with nothing, both located under the seat. Tonight I cleaned every connection I could find looking for corrosion. Didn't find any but put di-electric grease in all the connections anyways. It was acting differently tonight. Now the display unit just flickered but when I turned the lights on the display would come on and the engine would keep running. Throttle had no effect on it. Ive been told that the black/yellow wire is the ground so I tested for a ground from the connector at the cluster to the battery and there was none. I also could not find a ground from the battery to the frame. I do not usualy work on 4 wheelers but do they not use the frame for a ground as a car would? Anyboey have a wireing diagram?
Grutt is offline
post #4 of 13 Old 08-08-2009, 03:15 PM
Feedback Score: 2 reviews
canada's t4's Avatar
Garage
its sounds like the buss connector under the rear fenders by the gas tank is buggered up and causing all your problems chances are ur bike is an 05 and this is your problem it causes all sorts of crazy mishaps and is easily fixed just search buss connector mod
`2005 bruteforce 750i
26 inch mudlites
moose power module
passenger seat
warn winch
fairing
muzzy pro
`1996 ski doo formula 3 600 triple(AKA the purple screamer)
`2006 brutefore 650i( getting complete rebuild from frame up)
canada's t4 is offline
post #5 of 13 Old 08-08-2009, 03:29 PM
your battery is bad happened to me
your battery is bad had the same thing happen to me
RokMar is offline
post #6 of 13 Old 08-08-2009, 03:31 PM
its your battery been there done that
RokMar is offline
post #7 of 13 Old 08-08-2009, 03:37 PM
i have a problem my display flashes back and forth from 2wd to 4 wd at 1 sec interval book says its the engine brake actuator. is this correct. where is this located . ordered book not here yet . kaw 05 750 v-twin frickin monster. put on some Maxis and toolbox on back the rest is stock. any help would be kool. already took it to dealer they said wires were lose. the next day same problem. there the one with lose wires. no i didnt get a refund $89.00 bill
RokMar is offline
post #8 of 13 Old 08-08-2009, 09:40 PM Thread Starter
Quote:
had battery tested by dealer. said its ok. read about that bus connector under the rear fender. pulled every connector apart and found no corrosion. blew them all out and covered in di electric grease. still said weird problems.
Grutt is offline
post #9 of 13 Old 08-09-2009, 07:09 PM Thread Starter
Bike is an 07. key off voltage of the battery is 12.43V running voltage is 12.43V. Shouldn't it be charging around 14v when bike is running. think this could cause the problem?
Grutt is offline
post #10 of 13 Old 08-09-2009, 09:34 PM Thread Starter
Quote:
Found bus connector mod. Found rear bus connector. there is no black/yellow wire in it tho which was supposed to be the problem wire, the ground. there is a yellow bus connector further down the harness full of black/ yellow wires. tiny bit of corrosion in the white bus connector cleaned it, no change. None in the yellow. Have no continuity from yellow bus connector to the negative on the battery or to the frame. Does anybody know where the frame ground is located.
Grutt is offline
05 brute force when you turn the lights on engine shuts off
06 650 brute force cluster shuts off when revved
2006 750 brute force no power when key is turned on
2006 brute force 750 key will not turn off power
2006 kawasaki 650 shut off when turn lights on!
2006 kawasaki brute force no electrical power
bruce force 750 electric start no pwr
brute force 750 cluster not working
brute force display shutting off
brute force electric start turns off display
electric fan part kawasakie 2005 750i
how to fix kawasakie 650 shuts down when headlights turned on
what is causing engine brake on 2006 kawasaki brute force 750 to keep buzzing
Should I buy this 2005 BF 750 4x4i ?? gorsar Kawasaki Brute Force/Prairie/Bayou 11 08-08-2009 04:57 PM
06 650 4x4i new hmf utility , got a question on jets bjordan720 Kawasaki Brute Force/Prairie/Bayou 8 03-05-2008 03:02 PM
06 Kawasaki Brute Force 750 4x4i... BlazinOrange700 For Sale 3 11-28-2006 08:56 PM
07 650 4X4i jetting theskitzofrantic Kawasaki Brute Force/Prairie/Bayou 5 11-07-2006 02:27 PM
650 4X4i Service Manual theskitzofrantic Kawasaki Brute Force/Prairie/Bayou 2 10-30-2006 11:00 PM
