Prairie 300 4x4 leaking gas - Kawasaki ATV Forum
post #1 of 2 Old 08-23-2009, 12:47 PM Thread Starter
the gas is leaking out thru the carburetor drain tube. Is this a carb problem or maybe the fuel on/off/res switch? it will drain a tank of gas in a couple days.
lgatz55 is offline
post #2 of 2 Old 08-23-2009, 01:15 PM
Sounds to me that the float is stuck or it needs a new needle seat/valve. When the bowl is full the float raises and shut the flow of fuel to the bowl by closing the needle valve. Sometimes you can just tap the bowl with a screw driver if the float is stuck. If you haven't run it in a while it may be "gummed" up inside. Also, the ethanaol fuels are reaking havoc on older fuel systems.
dmoyers is offline
06 kawasaki prairie has gas running out carburetor drain tube
1998 kawasaki 400 4x4 atv gas shut off
2000 300 prairie carburetor float diagram
2000 kawasaki prairie 300 carburetor has fuel overflow
2000 kawasaki prairie 300 leaks gas
2000 kawasaki prairie 300 leaks gas after it is turned off
2000 prarie 300 carburetor overflows
carburetor diagram for 2000 kawasaki bayou 300 4x4
diagram for a kawasaki 300 klf fuel shutoff valve
gas leaks out of carb on 01 kawasaki 300 prairie
kawasaki 300 prairie carb bowl
kawasaki prairie 300 carburetor diagram
kawasaki prairie 300 carburetor leaking
Leaking Gas Screamin_99 Kawasaki Brute Force/Prairie/Bayou 20 11-03-2009 04:27 PM
Still leaking fuel orangecrush05 Kawasaki KFX700 V-Force 19 01-09-2009 12:02 AM
650 prairie leaking fuel papa0926 Kawasaki Brute Force/Prairie/Bayou 10 11-10-2008 06:22 AM
TECATE 4 oil leaking,NEED HELP GREENLIGHTNING Kawasaki Tecate 4 08-15-2004 08:29 PM
Leaking Gas mudboggin Kawasaki KFX700 V-Force 5 07-17-2004 04:59 PM
