Brute force broken belt - Page 2 - Kawasaki ATV Forum
post #11 of 37 Old 10-13-2009, 05:24 PM
Feedback Score: 1 reviews
Dont buy your belts from the dealers... huge mark up!! You can get one from Babbits for a great price! The dealer here wants 100.00 for a stock belt. I found another belt store that had it in stock for 48 dollars. That is rediculous! If you get a CDI they will usually override the switch. I dont know how to reset it. Search the maintenance section
2006 Red Brute Force 750, FST Trail kit, STG III cams, Full Muzzy, Dynatek CDI, Works G series Shocks, Venom 2000lb winch, Duro Powergrips w/ITP 108ss rims, Oil Cooler, Engine Ice, HDPE skids from Chuck, some homemade clutch snorkels, EHS lid, K&N filter, ODI handgrips.
cmelendy is offline
post #12 of 37 Old 10-14-2009, 04:18 AM
PDiablo's Avatar
You reset the switch by pulling off the clutch cover and flipping it back to the normal operation position. It is just a toggle switch mounted to the top/inside of the clutch cover. Its very simple.
2008 BF750-
HMF, snorkeled, 27" IPT ML radials, a few home remedies
2003 Bayou 250-
k&n, jetted
PDiablo is offline
post #13 of 37 Old 10-14-2009, 09:18 AM
DaBrute's Avatar
Quote:
Originally Posted by 2008BeastBrute750 View Post
Well i got the new belt put on and rode it three times and seem to do completely fine then took it out last week and now my belt light is on and it wont go more than about 5 mph? Called dealer and he said the switch just needs to be reset. Can anyone please tell me how to reset the switch?
No need to pull belt cover to reset, under your seat at the back there is two plugs one grey and one black.Switch the plugs ,then just on the top of your cover there is a rectangle black box.Behind that is a 2-wire plug,unclip it.Now turn on your ignition (but don't start) wait 5-10 seconds until the light stops flashing fast, turn the key off then plug everything back in it's proper place. Your done.
Stock set up : they are supposed to go into limp mode when the hours reach around 100. But sometimes due to on of throttle riding the belt will get tripped.
P.S. Change dealers!!!! if the guy wouldn't tell you how to reset properly then he 's an a**hole and just want's to charge you to do it.
"Ride it like you stole it"
2009 BF750i
26" GBC Gators/Cultivators
VDI Copperhead ECU/sometimes
EPI Maroon Primary, Moose Armor,Moose hand guards,Wes Ind. Deluxe ass lounger,
Fully Snorked,Hastings Temp Guage,
Kujo's A-Arm Bushings
Clarion Audiotube
98' Honda 450ES
DaBrute is offline
post #14 of 37 Old 10-14-2009, 11:00 AM
Feedback Score: 3 reviews
Seymour's Avatar
also my dealer here charges around 70 for a belt which i dont think is really all that bad
06 BF 750, black plastics bone stock
Seymour is offline
post #15 of 37 Old 10-14-2009, 12:07 PM
NovaKaw650's Avatar
Garage
If the switch is tripped he will need to pull the belt cover to reset the switch.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #16 of 37 Old 10-14-2009, 12:12 PM
Babbits has the belt for a great price. I want to say its 39 dollars... ? In any case it is waaay cheaper than any dealer is going to be! Check it out
cmelendy is offline
post #17 of 37 Old 10-14-2009, 07:22 PM
Quote:
What is this Babbits that you speak of? What brand belt do they sell for $39? I could use a new belt and it would be sweet to get one cheaper.
Gunner is offline
post #18 of 37 Old 10-31-2009, 04:13 AM Thread Starter
Smile Thanks for the help
Alright thanks everyone for all this information. I ended up taking off the seat and switching the wires like Da Brute said to. I now have the complete brute force manual on a thumb drive. Well I did this a coulple of weeks ago and it turned the belt light off and ran fine FOR A COUPLE OF HOURS.... SNAP broken belt again. I have returned to afghanistan from my leave and its sitting at home with a broken belt. I got to talking to another guy here about it because he has an 09 model and I brought up the fact that it has a heavy duty clutch kit in it and had 29.5 swamp lites when I got it. After I got it I put stock size mud lites on it and he told me thats the problem. Its to heavy of a clutch for the little tires I have on it now vs. the big swamp lights I took off. I kinda thought about this theory myself but didnt know as this is the first kawasaki I have owned. Can anyone else elaborate on this? Is the clutch kit causing my belts to break? I do have the original clutch springs and clips i guess you call them. The guy before had the clutch kit put in when he purchased it from the dealership. Thanks for any information.
2008 Kawasaki Brute Force 750 4x4i (EFI),25" Mud Lites, 2" Lift, 1.5" Wheel Spacers, HD Clutch Kit, HMF Exhaust System w/ Quiet Core, Full Body Armor underneath,
3000lb Warn Winch
2003 Honda Rancher S 2" Lift, Warn Bumper W/Lights, 4-2-4 selector
2000 Chevy Silverado Z71, Flowmaster Dual Dumps, T-bars turned, 33" Mickey Thompson's, Memphis 12 Mojo(Sounds Sick!)
"I DONT GET STUCK, I JUST LOSE TRACTION AND STOP MOVING!"
2008BeastBrute750 is offline
post #19 of 37 Old 10-31-2009, 06:20 AM
NovaKaw650's Avatar
Garage
No, it's not.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #20 of 37 Old 10-31-2009, 05:24 PM Thread Starter
Any idea why then?
3000lb Warn Winch
Tags
750, belt, broken, brute, force
05' Brute Force 650 Oil in drive belt box? yqspilot Kawasaki Brute Force/Prairie/Bayou 0 07-23-2009 01:22 PM
It was a broken belt, more questions now... Willet Kawasaki KFX700 V-Force 9 08-12-2005 11:26 AM
Broken belt? Willet Kawasaki KFX700 V-Force 5 08-08-2005 06:12 AM
Belt on Brute Force bbertram Kawasaki Brute Force/Prairie/Bayou 19 09-28-2004 04:32 PM
broken belt on 700 uboatcmndr Kawasaki Brute Force/Prairie/Bayou 6 04-05-2004 02:37 PM
