Old 09-30-2009, 08:30 PM   #1
View VRDRAFT's Photo Gallery(0)
Default KVF650-1A carburetor removal
Does any one have a step by step instruction for KVF650-1A carburetor removal? Or a link to get them? I'm close but the choke cable lines have me baffled. At least I think that is what it is...
VRDRAFT is offline   Reply With Quote
Old 09-30-2009, 09:34 PM   #2
Feedback Score: 3 reviews
minimus's Avatar
View minimus's Photo Gallery(0)
Default
Here is a brute 750 manual. Its just remove the screws and pull out the plungers. You have two chokes one on each side. Make sure you stuff rags down intakes right after carb removal. If you drop anything like a screw your really screwed.
http://www.mmi.org/merrington/atv/files/br...eshopmanual.pdf
Brute Force AMR 840, 13:1 pistons, 4X cams, extended rockers, Big Kev's Performance Full race port, +1.5mm exhaust valves, +1 mm intake valves, muzzy pro, 39mm carbs, programmable dynatek cdi, custom airbox, JHmachine clutch, HPD plain primary spring
minimus is offline   Reply With Quote
Old 10-01-2009, 06:49 AM   #3
Default
Thanks a bunch that should help. I am assuming the Brute 750 & the 650 are about the same.
Old 10-01-2009, 07:55 AM   #4
Feedback Score: 8 reviews
asnowmobiler's Avatar
Default
They are the same if you have a 650i,the SRA's are different but the plungers still come out after removing the screws.
Officiallywas one of the fastest Prairies in the world
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,AMR ported intakes,programmable Dyna,30 shot of Boon,Brute Force Flywheel,stock carbs,stock exhaust,Flexx bars,Rox Risers,ODI grips,Tusk Dozer plow,ECT.
AMR 330 347 6800
brute force 750 carb removal
carburetor removal kawasaki 650 prairie
choke cable kawasaki brute force 650
how to clean carb on 2005 kvf650
how to remove 05 kawasiki carburator 650 brute force
how to remove carbs on 650 prairie kawaski
kawasaki 650 atv carberators removel
kawasaki kvf 650
kawasaki prairie 360 how to remove choke cable
kawasaki prairie 650 carb cleaning
kawasaki prairie 650 carburetor removal
kvf650 carburetor adjustment
remove carburetor kawasaki prairie choke cable
You may not post new threads
You may not post replies
Carburetor Question Chickenstick700 Kawasaki KFX700 V-Force 10 01-09-2009 05:36 AM
need KVF650/700 swing arm speedy81304_KVF700 Wanted 0 02-17-2007 04:57 AM
KVF650 A1 wheelie_king Buyer/Seller Feedback 1 10-27-2006 04:29 AM
Non Vacuum operated Carburetor MoSpeed Kawasaki KFX700 V-Force 1 01-16-2005 07:42 PM
KVF650 - as a FUV (Farm Utility Vehicle) DBCooper Kawasaki Brute Force/Prairie/Bayou 1 05-20-2003 03:16 PM
