Old 10-06-2009, 10:14 AM   #1
View scmuddog's Photo Gallery(0)
Default prairie starting problems
hey guys...i have a 2005 prairie 360 4wd....have some trouble starting it every time i ride.....once i ride for awhile i dont have the trouble....but it is hard to get it running and idling the first 30 min or so...any thoughts
scmuddog is offline   Reply With Quote
Old 10-06-2009, 05:01 PM   #2
greasemonkey's Avatar
View greasemonkey's Photo Gallery(0)
Default
I don't have any personal experience with the 360's but from what i've seen here this is a common problem with the 360's that is cured by adjusting the valves.That is why it changes when it is hot( clearence changes).
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline   Reply With Quote
Old 10-06-2009, 06:05 PM   #3
Default
hey thanks man....ill have to try that....it has a dyno jet in it...but i dont think that is the problem
Old 10-06-2009, 11:23 PM   #4
View buddahboy357's Photo Gallery(0)
Default valves
i agree adjust your valves the exhaust will tighten up
2005 prairie 360 2 inch lift 26 inch mudlite xl,s full skids snorkles 2500 warn jet kit hmf
buddahboy357 is offline   Reply With Quote
2008 kawasaki prairie 360 starting problems
360 prairie cold blooded
common problems kawasaki prairie 360
kawasaki prairie 360 electric start wont work
kawasaki prairie 360 starter
kawasaki prairie starting problems
kawasaki prarie 360 cold running problems
kawaski prairie 360 starting
prairie 360 front bumper
prarie 360 starting problem
starting kawasaki prairie
starting problems with kawasaki 360 prarie atv
You may not post new threads
You may not post replies
'j95 Bayou 220 Starting Problems thajuice Kawasaki Brute Force/Prairie/Bayou 0 09-18-2009 07:20 AM
Starting Problems gitrdone Kawasaki KFX700 V-Force 4 05-04-2009 03:05 PM
starting problems MUddogg Kawasaki KFX700 V-Force 3 12-12-2008 05:20 PM
Put the 40 pilots back in and still has problems starting krewzlo Kawasaki KFX700 V-Force 17 05-16-2007 06:20 AM
starting problems vtprairie03 Kawasaki Brute Force/Prairie/Bayou 9 06-06-2005 05:16 PM
