How to: Reset Prairie 360 Belt Light - Kawasaki ATV Forum
post #1 of 2 Old 10-10-2009, 09:52 AM Thread Starter
Feedback Score: 1 reviews
700ccMARSHMELLOW's Avatar
Here is a step by step procedure for reseting the belt light on a Prairie 360.
First, disconnect the two wire plug on the belt sensor (rectangular box rivited to the top of the clutch cover
Then, find the black and grey plugs up under the gas tank cover. These are on the clutch side, just above the belt snsor.
Press the tab and unplug them both
Swap the greay to the black, and black to the grey
Cut the key on for about 5 seconds, or untill you see the flashing lights momentarily blink differently. Then cut the key back off.
Plug the grey and black plugs up the way they were. Don't foget to fasten them back up to the frame, if you pulled the strap off of them.
Plug the belt sensor back in.
Cut the key on to verify the procedure worked.
700ccMARSHMELLOW is offline
post #2 of 2 Old 10-15-2009, 11:14 AM
Insane
You have no idea how frustrated this has made me. I re-set the belt sensor using a different method years ago. It stopped flashing for a while and started up again. I figured I would live with it. I was out hunting in North TX, when my ATV started hesitating. It's idle was normal, but it would not accelerate. I was constantly getting stuck (yes in TX) and having to use my wench to get back. There was not enough power to get me out of a medium mud puddle let alone cruse faster than idle. I disconnected the belt sensor plug as previously and nothing. I cleaned the filter, carb & flushed out the tank, and it started working again. Again I went out hunting and it started acting up again. This time, I re-built the carb. Nothing! Finally I found this link, and ten minutes later she runs like a champ. I am from Alaska, thank God, this did not happen in the Bush!!! Kawasaki needs to get a clue.
ChowDawg is offline
Can someone help me with a belt light reset on 2004 Prairie? nyroc Kawasaki Brute Force/Prairie/Bayou 17 10-15-2009 11:19 AM
Belt light reset. chitownpete Kawasaki KFX700 V-Force 2 09-04-2008 08:45 PM
help!! need to reset the belt light Brutus Forsus Kawasaki Brute Force/Prairie/Bayou 3 04-13-2008 04:56 PM
belt reset light h2smokin Kawasaki Brute Force/Prairie/Bayou 6 10-26-2007 06:17 AM
How to reset the belt light on a V? Forceof1 Kawasaki KFX700 V-Force 3 03-12-2004 09:35 PM
