fuel filter/backfire problem - Kawasaki ATV Forum
post #1 of 7 Old 11-21-2009, 11:50 AM Thread Starter
Post fuel filter/backfire problem
newbie to the site,love it so far..question..where is the stock fuel filter/shouldnt it have a inline filter also..oh ya ive got a 2002 650 prarie 4x4 that might help..ive recently picked up a backfire problem..so now im learning to work on it..joy any advice will help..
beaman is offline
post #2 of 7 Old 11-22-2009, 08:48 AM
i put a in line filter on my 02 praire pull your spark plugs see if they are black my o2 sat for a while had bad gas i went thu the carbs cleaned everything i also adjusted the valves the problem was my choke plungers were sticking which made me real rich my bike kept popping thru carb check your spark plugs that will show you which carb is bad i also put seafoam in gastank my o5 brute did the same thing when i let it sit without fuel stabilizer in it hope this helps ya
novass is offline
post #3 of 7 Old 11-22-2009, 09:36 AM
Feedback Score: 1 reviews
Quote:
Year and model?
Hunterworks is offline
post #4 of 7 Old 11-23-2009, 04:44 AM Thread Starter
thanks novass..did helpme out,and reassurred what ive done so far.1st drained bowls on carbs,put seafoam in tank..then while looking i noticed boot wasnt connected to front carb on bottom.fixed that..still popping..took carb off boots and took all jets and throttle stop out and cleaned with deep creep..got back together runs alot better but sti;; has small pop..havent changed plugs again yet.but will today..didnt take carbs off because i wasnt sure about choke cable ..is it tricky..again thanks
beaman is offline
post #5 of 7 Old 11-23-2009, 07:20 PM
are you sure the carb boot didn't have a tear under the strap- had that with my 06' 750- you might need to adjust your air/fuel screw, check your plug wires to make sure those aren't split either. did you check/change your oil? go through water before the problem started? where in Ohio are you
bigdaddybf is offline
post #6 of 7 Old 11-24-2009, 09:07 AM Thread Starter
Arrow getting better
not 4 sure but will check next time carbs r off..might spray to see if it leaking..no..when whoever had them off last,put them back on ,they had the clamp part located where the carbs wouldnt/couldnt come down far enough.or maybe it just vibrated out /who no's..im in preble county/sw ohio..u..also oil level is fine //needs changed baad..just got filter.havent had it in any water/mostly utility use..actually i bought it with this popping..guy told me he had it looked at and they told him it was plugs..he had plugs but just (said) he hadnt had the time to change im..poppin got worse..i changed the plugs..still popping/the got worse/then lost power..i think im on the right track with carb
thanks 4 info..
beaman is offline
post #7 of 7 Old 11-25-2009, 05:28 PM
on the choke plungers take them out clean them real goodyou can strech the springs some on the plungers i did that to my 05 brute a year ago and they are still good. i orderd new choke cables for my 650 praire when i had it they were a different part number i think they were a little bit longer.check with your dealer.i sold my 02 a couple of tears ago its still fine
novass is offline
2005 brute force 750 fuel filter location
2005 kawasaki brute force 750 fuel filter
2009 kawasaki 250 cc bayou fuel filter location
brute force 650 fuel filter
brute force fuel filter
can i put a in line fuel filter on 05 kvf750 brute force
does a 2008 brute force have a fuel filter
fuel filter kawasaki 650 brute force
fulefilterfor2009bruteforce750
gas filter kawasaki brute force
were is the fuel filter on a 2011 650 brute force
where is the fuel filter on a 05 750 brute force
where us the fuel filter on a 2008 kawasaki 650
Fuel filter Enigma Kawasaki KFX700 V-Force 9 06-16-2008 06:21 PM
fuel filter Footy Kawasaki Brute Force/Prairie/Bayou 3 10-24-2007 06:17 PM
WHich air filter and backfire screen..... deadpresidents Kawasaki Brute Force/Prairie/Bayou 7 05-14-2005 10:15 PM
Fuel Filter migraine Kawasaki Mojave/Lakota 5 11-14-2004 04:46 AM
Solved my Backfire after WOT problem Mikeyboy_esq Kawasaki Brute Force/Prairie/Bayou 2 05-04-2004 03:38 PM
