Old 12-09-2009, 05:29 PM   #1
View sierraoffroad's Photo Gallery(2)
Default 2009 prairie 360 4x4 won't stay running
Hello everyone i just purchased my first new quad ever. a 2009 prairie 360 4x4 in camo. When i brought the machine home i warmed it up on choke (temp was in the 30-40 range) and gradually eased off the choke and the engine slowly died. i know the machine has fresh gas in it. i restarted the engine and gently tapped the throttle to keep the rpm's up and used the choke to keep it running and then it slowly died again. i took it for a gentle trail ride and after about 30 mins of varying speeds 20mph and slower it stayed running, but seemed to be running hot. is this just a part of break in, or are the valves a little tight??
otherwise i'm pleased with my purchase. also is there a non cv carb available for this machine??
thanks
sierraoffroad is offline   Reply With Quote
Old 12-09-2009, 10:39 PM   #2
Camo Joe's Avatar
View Camo Joe's Photo Gallery(0)
Default Idle
If it is under any warranty then let them know your problem ....If not it sounds like you may just need to idle it up a bit with the idle adjustment.
Good Luck!..............
Camo Joe is offline   Reply With Quote
Old 12-10-2009, 03:12 AM   #3
Default
ok thanks camo joe. i'd prefer to make the simple adjustments myself since the dealer i bought it from is on the edge of going belly up and their one service tech isn't the brightest.
Old 12-10-2009, 04:52 PM   #4
Default
i'm leaning toward the exhaust valve being too tight. i pulled the plug and it appears to be a bit whitish. i suspect a lean running condition. i read on another the valve spec for the exhaust is .15-.20mm or .18mm?? anyone else know for sure?
Old 01-03-2010, 07:48 PM   #5
dafoosa's Avatar
View dafoosa's Photo Gallery(0)
Default
I have had two 360's and both were plagued with the exhaust valve tightening up,when the bike would get hard to stay running once warmed up I would have to readjsut the exhaust valve
dafoosa is offline   Reply With Quote
2003 kawasaki prairie 360 4x4 will not idle
2009 kawasaki prairie 360 4x4 reviews
360 prairie leans out and dies
how to beef up my prairie 360
kawasaki 360 prairie 4x4 idle adjustment
kawasaki atv 360 prairie wont idle
kawasaki prairie 360 idle problems
kawasaki prairie 360 rough idle
kawasaki prairie 360 rough idols and dies
kawasaki prairie 360 runs rough
kawasaki prairie 360 wont idle
kawasaki prarie idles rough
prairie 360 wont idle right
You may not post new threads
You may not post replies
07 Brute SRA wont stay running tomalaina Kawasaki Brute Force/Prairie/Bayou 2 12-06-2009 05:27 PM
Prairie 360 Running Poorly MarkGleason Kawasaki Brute Force/Prairie/Bayou 8 02-06-2007 09:07 AM
Quads wont stay running GoonGrinch Kawasaki Brute Force/Prairie/Bayou 2 06-23-2003 07:32 PM
wont stay running? vtprairie03 Kawasaki Brute Force/Prairie/Bayou 6 05-25-2003 04:42 PM
